1:1 Balun for HF wire dipoles
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 8 Haziran 2014 başlatılmıştır.
    Heres a neat 1:1 50 ohm balun for use on HF horizontal wire dipoles. It uses an AM radio ferrite rod, with 3x14 turns of wire. 10-14 turns should be good for 2-30MHz. I used 18SWG enammeled copper wire. It all fits in a small project box. Great for setting up portable. For 20 metres, I started with 6 metres of wire per element, and trimmed each down until it has minimum S.W.R. I managed to get a 1:1.1 S.W.R. on my desired frequency. Bandwidth from the resonant frequency is about 200KHz either way, any more needs an ATU. The wire and ferrite core I had already, the box, terminal plugs and SO-239 came to about £6.
    Bandwidth can be increased by more spacing between each trifilar turn. I didn't have room on this tiny ferrite rod, but it performs OK.
    [​IMG][​IMG]
    Schematic diagram
Benzer Konular - Balun wire dipoles
