1.25V to 25V DC Ajustable Power Supply
Konusu 'Güç Kaynakları - Besleme Devreleri' forumundadır ve guclusat tarafından 24 Şubat 2014 başlatılmıştır.
    Online
    WARNING! Building circuits that use transformers requires high voltages, which can be lethal. If you are not experienced, do not attempt building projects that use high voltages. The Electronics Zone is not responsible for any damages or injury caused.
    Description
    This adjustable LM350 regulated power supply can deliver up to 3A and the output voltage is adjustable from 1.25VDC to 25VDC. A panel voltmeter with a suitable rating can be connected to precisely set the output voltage. This circuit has an output switch which allows the user to turn on and off the output more cleanly than with the main power switch.
    Circuit Diagram
    Son düzenleme: 6 Şubat 2015
