Son kullanma tarihi geçmiş, bayatlamış bir tarayıcı kullanıyorsanız. Mercedes kullanmak yerine tosbaya binmek gibi... Websiteleri düzgün görüntüleyemiyorsanız eh, bi zahmet tarayıcınızı güncelleyiniz. Modern Web standartlarını karşılayan bir tarayıcı alternatifine göz atın.
I used input frequency 10Hz to output 1Hz.This is a 10 divider circuit.
When we need a standard digital clock 1 Hz. but we have the input signal is square wave form 10 Hz so need to reduct it lower with digital frequency divider circuit 10 times
I suggest that IC 4017 (Decade Counter / Divider with 10 Decoded) from the familiar to make a 10 LEDs running light circuits, but this circuit we used a frequency dividing circuit 10 times, too.
It’s interesting because it uses a single IC run it. The circuit is very simple. Would not be very descriptive. Enjoy it.
Circuit 1 Hz Timebase by IC 4017
circuit 4027 divide by 2 counter
When you want to decrease the frequency in 2 digital times circuits or Divide Frequency by 2 counter. I advises use IC 4017, because seek easy cheapness can be usable good various.
