12 Volt DC Floresan Lamba Sürücü devresi (12 Volt DC Fluorescent Lamp Driver )
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 6 Nisan 2012 başlatılmıştır.
    Online
    A number of people have been unable to find the transformer needed for the Black Light project, so I looked around to see if I could find a fluorescent lamp driver that does not require any special components. I finally found one in Electronics Now. Here it is. It uses a normal 120 to 6V stepdown transformer in reverse to step 12V to about 350V to drive a lamp without the need to warm the filaments.
    C1 100uf 25V Electrolytic Capacitor
    C2,C3 0.01uf 25V Ceramic Disc Capacitor
    C4 0.01uf 1KV Ceramic Disc Capacitor
    R1 1K 1/4W Resistor
    R2 2.7K 1/4W Resistor
    Q1 IRF510 MOSFET
    U1 TLC555 Timer IC
    T1 6V 300mA Transformer
    LAMP 4W Fluorescent Lamp
    MISC Board, Wire, Heatsink For Q1
    Notes:
    1. Q1 must be installed on a heat sink.
    2. A 240V to 10V transformer will work better then the one in the parts list. The problem is that they are hard to find.
    3. This circuit can give a nasty (but not too dangerous) shock. Be careful around the output leads.
    Son düzenleyen: Moderatör: 1 Kasım 2015
