16 LED Knight Rider using 74HCT138 microcontroller
Konusu 'Elektronik Devreler' forumundadır ve uydudoktoru tarafından 27 Şubat 2015 başlatılmıştır.
    Part list:
    8x LED (red)
    1x 180 ohm
    1x 10k ohm
    1x 33k ohm
    1x 2u2/16V
    1x 74HCT191
    1x 74HCT132
    2x 74HCT138
    1x 78L05
    1x 47uF/16V
    1x 100n
    2x 1N4007
    Yet another version:
    Here an example with 4 TTL ICs. This is I think the cheapest solution with standard logic ICs. The 74HCT191 is a Presettable Synchronous 4-Bit Binary Up/Down Counter. Pin 14 is the clock input (from the osc.) Pin 5 is the Up/Down input, this lets the counter counts up or down (via the flip-flop) when reaching the last LED. Enable the counter by connecting pin 4 to GND. The counter generates 4 bits data at the 4 outputs (Q0 to Q3) The data goes to the two 3-to-8 line decoder/demultiplexers, the trick is this, you have 3 address inputs (btw 2^3 = 8) and two Enabling inputs (pin 4 and 6), with these you can enable each 74HCT138 individually. At the first clock of the oscillator (N3), the counter starts at 0001 (first LED on), so pin 4 and 6 are both 0, so only one 74HCT138 is enabled at a time. When reaching the 9th clockpulse, the two 74HCT138s flip, because the counter is at 1001.
Benzer Konular - LED Knight Rider
