200 Transistor Circuits
Konusu 'Elektronik Cihaz Katalog Bilgi Döküman Ve Dergiler' forumundadır ve uydudoktoru tarafından 19 Ekim 2012 başlatılmıştır.
    Here is a list of the contents:Ammeter 0-1A ​
    Automatic Garden Light
    Automatic Light
    Bench Power Supply
    Boom Gate Lights
    Boxes
    Buck Converter for LEDs 48mA
    Buck Converter for LEDs 170mA
    Buck Converter for LEDs 210mA
    Cable Tracer
    Clock - Make Time Fly
    Colpitts Oscillator
    Constant Current Source
    Dancing Flower
    Door-Knob Alarm
    Dynamic Microphone Amplifier
    Electronic Drums
    Fog Horn
    FRED Photopopper
    Gold Detector
    Guitar Fuzz
    Hartley Oscillator
    Heads or Tails
    Hearing Aid Constant Volume
    Hearing Aid Push-Pull Output
    Hearing Aid 1.5v Supply
    Hee Haw Siren
    IC Radio
    LED Detects Light
    LED Flasher 1-Transistor
    LED Torch with Adj Brightness
    LED Torch with 1.5v Supply
    Lie Detector
    Light Alarm-1
    Light Alarm-2
    Light Alarm-3
    Light Extender for Cars
    Listener - phone amplifier
    Make Time Fly!
    Making 0-1A Ammeter
    Metal Detector
    Microphone Pre-amplifier
    Motor Speed Controller
    Movement Detector
    Multimeter - Voltage of Bench Supply
    Music to Colour
    On-Off via push Buttons
    Phaser Gun
    Phone Alert
    Phone Tape-1
    Phone Tape-2
    Phone Transmitter-1
    Phone Transmitter-2 Phase-shift Oscillator
    Resistor Colour Code
    Robo Roller
    Robot Man - Multivibrator
    Schmitt Trigger
    SCR with Transistors
    Second Simplest Circuit
    Signal by-pass
    Signal Injector
    Simple Logic Probe
    Siren
    Solar Engine
    Solar Engine Type-3
    Solar Photovore
    Sound to Light
    Sound Triggered LED
    Speaker Transformer
    Spy Amplifier
    Strength Tester
    Sun Eater-1
    Sun Eater-1A
    Super Ear
    Ticking Bomb
    Touch Switch
    Train Throttle
    Transistor Pinouts
    Transistor Tester-1
    Transistor Tester-2
    Trickle Charger 12v
    Walkie Talkie
    Walkie Talkie - 5 Tr - circuit 1
    Walkie Talkie - 5 Tr - circuit 2
    Worlds Simplest Circuit
    White LED Flasher
    White LED with Adj Brightness
    White Line Follower
    Zener Diode (making)
    0-1A Ammeter
    5 LED Chaser
    5 Transistor Radio
    6 Million Gain
    6 to 12 watt Fluoro Inverter
    12v Relay on 6v
    12v Trickle Charger
    20watt Fluoro Inverter
    27MHz Door Phone
    27MHz Transmitter
    27MHz Transmitter - no Xtal
    27MHz Transmitter-Sq Wave
    27MHz Transmitter-2 Ch
    27MHz Receiver
    27MHz Receiver-2
    303MHz Transmitter
    Son düzenleyen: Moderatör: 30 Nisan 2016
