35v to 60V input, 600W Output Dual-Phase Synchronous Converter with 97% Efficiency
Konusu 'Güç Kaynakları - Besleme Devreleri' forumundadır ve guclusat tarafından 14 Ocak 2015 başlatılmıştır.
    Online
    This 600W wide voltage input dual phase power converter uses two emulated current-mode controllers 180 degrees out of phase to minimize input and output ripple current. Compared to conventional isolated power converters, this synchronous buck architecture provides a reduced footprint and BOM cost at higher levels of efficiency, greater than 97% over several operating conditions.
    Features
    • Two-phase buck converter
    • 600W output power
    • 35V to 60V maximum input voltage range
    • Output voltage of 12V at 50A
    • This reference design board is tested and supported with design files and an application note
Benzer Konular - 35v 60V input
