3A 6V/12V Solar Charge Control
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 21 Haziran 2013 başlatılmıştır.
    This solar charge control combines multiple features into a single design: 3A current rating, low dropout voltage (LDO), range of voltage adjustment (accommodates 6 & 12V lead-acid batteries), reverse polarity protection, low parts cost ($5.90) and low parts count (14 components). High performance is attributed to the application of the common LM358 op amp and TL431 adjustable shunt voltage regulator.
    Specifications
    • Max solar panel rating (12V): 43W (open circuit solar panel voltage = 18 to 20V)
    • Max solar panel rating (6V): 22W (open circuit solar panel voltage = 9 to 10V)
    • Maximum input voltage: 36V
    • Output voltage range: 4.5 to 15V (continuously adjustable)
    • Max power dissipation: 17W (includes power dissipation of D3)
    • Typical dropout voltage: 0.7V @ 3A (less @ lower currents)
    • Maximum current: 3A (current limiting provided by solar panel characteristics)
    • Voltage regulation: 5mV (voltage change no load to full load)
    • Battery discharge: 100µA (most commercially units discharge at typically 5mA)
    • Reverse battery protection: Control shuts down if battery is inadvertently connected reverse
    Solar Charge Control Circuit Schematic
Benzer Konular - 12V Solar Charge
  4. uydudoktoru
  5. uydudoktoru
