40 Watt Transmitter
Konusu 'Fm Verici Devreleri' forumundadır ve guclusat tarafından 2 Mart 2013 başlatılmıştır.
    A 2 stage 40w amp using 28v devices. RF input power should be between 0.5 and 1 watt. The diagram below shows a 2N3375 driving a 2N5643 but there are many other devices that will work. I used these 2 transistors just because they were cheap at the time. If any of the variable capacitors are at full capacitance you can pad them out with a fixed ceramic capacitor of suitable value. Extra capacitace also might be needed on the base of the transistors (i had to add 3 100pF capacitors on the base of the 2N5643).
    heres a built example below. The transistors are bolted to a piece of right angle aluminium which is fixed to the metal chassis to dissipate heat effectively:
    Son düzenleme: 28 Nisan 2017
