500mW FM Transmitter by BC549 (BC549 ile yapılmış bir 500mW FM Verici devresi)
Konusu 'Fm Verici Devreleri' forumundadır ve guclusat tarafından 16 Aralık 2011 başlatılmıştır.
    The TX500 is a simple to build 500mW FM Transmitter. It consists of three blocks; modulator / oscillator, two stage 500mW VHF amplifier and LED based power meter. The TX500 allows to transmit audio signals to FM band at frequencies from 88 MHz to 108 MHz. Due to the very low power consumption of less than 100mA the circuit may be perfectly powered by using 9-12V battery or power supply if you prefer. The circuit has been divided into separate stages so that it is be better for everyone to understand how every part works independently.
    Son düzenleme: 6 Kasım 2017
Benzer Konular - 500mW Transmitter BC549
