All chına mobıles code
Konusu 'Cep Telefon Tamir Ve Programları' forumundadır ve guclusat tarafından 26 Kasım 2009 başlatılmıştır.
    *#66*# Set Factory Mode CONFIRMED
    *#8375# Show Software Version CONFIRMED
    *#1234# A2DP ACP Mode CONFIRMED
    *#1234# A2DP INT Mode CONFIRMED
    *#0000# + Send : Set Default Language CONFIRMED
    *#0007# + Send : Set Language to Russian CONFIRMED
    *#0033# + Send : Set Language to French CONFIRMED
    *#0034# + Send : Set Language to Spanish CONFIRMED
    *#0039# + Send : Set Language to Italian CONFIRMED
    *#0044# + Send : Set Language to English CONFIRMED
    *#0049# + Send : Set Language to German CONFIRMED
    *#0066# + Send : Set Language to Thai CONFIRMED
    *#0084# + Send : Set Language to Vietnamese CONFIRMED
    *#0966# + Send : Set Language to Arabic CONFIRMED
    CHINESE MODELS:
    default user code: 1122, 3344, 1234, 5678
    Engineer mode: *#110*01#
    Factory mode: *#987#
    Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
    Restore factory settings: *#987*99#
    LCD contrast: *#369#
    software version: *#800#
    software version: *#900#
    set default language: *#0000# Send
    set English language: *#0044# Send
    set English language (new firmware): *#001# Send also
    Service codes BenQ:
    software version: *#300#
    test mode: *#302*20040615#
    Service codes Pantech:
    software version: *01763*79837#
    service menu: *01763*476#
    reset defaults (phone/user code reset to default): *01763*737381#
    Service codes **x, 5xx:
    software version: *#79#
    software version: *#837#
    Service codes VK200, VK2000, VK2010, VK2020, VK4000:
    service menu: *#9998*8336# (hold #)
    reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
    Service codes LG:
    software version: 2945#*#
    Service codes Sony-Ericsson:
    J100 software version: #82#
    Service codes Fly:
    2040(i) reset defaults: *#987*99# Send
    MX200 reset defaults: *#987*99# Send
    MX200 software version: *#900# Send
    SL300m reset defaults: *#987*99# Send
    SL300m software version: *#900# Send
    SL500m reset defaults: *#987*99# Send
    SL500m software version: *#900# Send
    MP500 reset defaults: *#987*99# Send
    MP500 software version: *#900# Send
    Set language to English: *#0044#
    Set language to Russian: *#0007#
    Service codes Konka:
    C926 software version: *320# Send
    C926 set default language: *#0000# Send
    C926 set English language: *#0044# Send
    Service codes GStar:
    GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
    Service codes Motorola:
    Motofone F3 software version: **9999* Send
    C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
    C138, C139, C140 software version: #02#*
    C155, C156, C157 software version: #02#*
    C257, C261 software version: #02#*
    V171, V172, V173 software version: #02#*
    V175, V176, V176 software version: #02#*
    C168, W220 software version: *#**837#
    W208, W375 software version: #02#*
    ZTE Mobile1- *938*737381#
    2- PHONE WILL DIPLAYED DONE
    3- POWER OFF YOUR PHONE AND POWER ON AGAIN
    alcatelE205
    unlocking phone code,only press***847# without simcard
    E900 software version: *#5002*8376263#
    E900 full reset: *2767*3855#
    Service codes Spice:
    S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
    S410 engineer mode: *#3646633#
    S900 software version: *#8375#
    S900 serial no: *#33778#
    Service codes Philips:
    S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
    Service codes "Chinese" models:
    Service codes BenQ:
    Service codes VK-Mobile **x, 5xx:
    service menu: *#85*364# (hold #)
    Service codes LG:
    KG300 NVRAM format: 2945#*# -> menu 15
    Service codes Fly:
    M100 software version: ####0000#
    Service codes Motofone-F3:
    ***300* Set SIM Pin
    ***310* / ***311* SIM Pin ON | OFF
    ***000* Reset Factory settings
    ***644* Set Voicemail number
    ***260* / ***261* Auto keypad lock ON | OFF
    ***510* / ***511* Voice Prompts ON | OFF
    ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
    ***200608* Send: software version
    ***200606* Send: software version
    ***200806* Send: flex version
    ***250* / ***251* Keypad tones ON | OFF
    ***470* Select time format
    ***500* /***501* Prepaid Balance Display ON | OFF
    ***520* Change language
    and "yes"''
    chiniss cord & pin out
    some chinese Mobile Code And Pinouts :::::::::::>>>>>>>>>
    Service codes BenQ:
    Service codes LG:
    Service codes Fly:
    MP500 reset defau
    More some codes for reset mobile china
    *#77218114#
    *#881188#
    *#94267357#
    *#9426*357#
    *#19912006#
    *#118811#
    *#3646633#
    CHINESE MODELS:
    for n95 that trips off on making call use
    *#3646633#
    goto misc item 6,and goto amr and press center botton
