Amplifier 10mWatt - 6Watt Profline (MicroStripline BFR91&BFR96&2SC1971)
Konusu 'Fm Verici Devreleri' forumundadır ve guclusat tarafından 17 Mayıs 2010 başlatılmıştır.
    BFR91-BFR96(S)-2SC1971 6 Watts FM broadcast (87,5-108MHz) Profline Broadband RF-amplifier
    All component values are drawn on the .comp and .silklayer bitmaps, with the following
    exceptions;
    1.- mount a ferroxcube bead (3 mm diameter, 5 mm length) over one of the wires of the 56E
    resistor (i.e. the wire wich is connected to the base of the 2SC1971 rf-transistor)
    2.- the 1uH and 4.7uH coils are ready-made molded type coils.
    3.- resistor values are in Ohms, 0.25watts (carbon or metalfilm).
    4.- the 47E adjustable resistor measures 10mm diameter, vertical mount (Piher).
    5.- all capacitor are ceramic except the 10nF and 100nF ones, these are multilayer types.
    6.- the two trimmer capacitors are 22pF, Green (Philips).
    7.- the two 150E resistors (at the collector of the BFR96(S) are mounted vertically.
    Son düzenleme: 7 Ekim 2012
Benzer Konular - Amplifier 10mWatt 6Watt
