Apple Iphone 3G,3GS, iPad Parts Datasheets (Component Schematic Diagram and Info)
Konusu 'Karışık Cihaz Tamir Bilgileri' forumundadır ve guclusat tarafından 13 Ağustos 2011 başlatılmıştır.
    Apple Iphone 3G and 3GS IC Parts Datasheets(Component Schematic Diagram and Info)
    For Hardware Pro's and Advance troubleshooter's Guide
    3G
    3GS
    SST SST25VF080B 1 MB SERIAL FLASH
    http://www.alldatasheet.com/datashee...T25VF080B.html
    Samsung ARM-based CPU (markings: 339S0036 ARM EMC567DB 819 8900B N182F0A3 0825 7511.101 ZPD8163Y)
    with DDR SDRAM Samsung
    http://datasheet.octopart.com/K4X1G1...eet-472067.pdf
    ST MICROELECTRONICS LIS331 DL ACCELEROMETER
    LIS331DL pdf datasheet, FREE from datasheetz.com: MEMS motion sensor 3-axis - *amp;**177 2g/*amp;**177 8g smart digital output ***34;nano***34; accelerometer STMicroelectronics
    INFINEON SMP3i SMARTi POWER MANAGEMENT IC
    http://www.infineon.com/cms/en/produ...19ebec03f05327
    Skyworks SKY77340 Power Amp. Module (824-915 MHz Power Amplifier Module Quad)
    http://www.datasheetpro.com/425257_d...datasheet.html
    Infineon PMB 6952 UMTS Transciever
    http://infineon.com/cms/en/product/c...12ab6ac4b80611
    Triquint TQM676031 WCDMA/HSUPA power amp
    An integrated 3-V linear UMTS Band 1 power amplifier (PA),
    duplexer and transmit filter module, with output power detector.
    It supports HSUPA operation with transmission data-rates up to 10 Mbits/s.
    http://www.triquint.com/docs/o/TQM676021/tqm676021.pdf
    Triquint TQM666032 WCDMA/HSUPA power amp
    Similar like TQM676031, but for Band 2 operation.
    http://www.triquint.com/docs/o/TQM666022/tqm666022.pdf
    Triquint TQM616035 WCDMA/HSUPA power amp
    WCDMA/HSUPA PA-duplexer module for Band 5 and 6.
    datasheet unavailable
    Numonyx PF38F3050M0Y0CE 16 MB NOR Flash - 8 MB Pseudo-SRAM
    http://www.numonyx.com/Documents/Mar...ORwireless.pdf
    Infinieon Digital Baseband Processor
    NXP Power management
    http://people.openmoko.org/tony_tu/G...50633DS_02.pdf
    Linear Technology LTC4088-2 Battery charger/USB controller
    http://cds.linear.com/docs/Datasheet/40881fb.pdf
    Infineon PMB2525 Hammerhead II GPS
    PMB2525 datasheet, Pinout ,application circuits HammerheadTM II - PMB 2525
    Wolfson WM6180C Audio Codec
    Wolfson Microelectronics plc: : CODECs
    Broadcom BCM5974 Touchscreen controller
    no datasheets available
    NATIONAL SEMICONDUCTOR LM2512AA DISPLAY INTERFACE
    http://www.national.com/ds/LM/LM2512A.pdf
    Toshiba TH58G6D1DTG80 8GB Flash (8GB model!)
    Marvell 88W8686 WiFi
    88w8686 .pdf Ebook Free Download
    CSR BlueCore6-ROM Bluetooth
    http://downloads.openmoko.org/develo...2520Issue1.pdf
    ---------- Sonra gönderilen Saat 03:10 ---------- İlk önce gönderilen Saat 03:09 ----------
    phone 3gs main board......
    ---------- Sonra gönderilen Saat 03:14 ---------- İlk önce gönderilen Saat 03:10 ----------
    this is iphone 3gs main board from the bottom hardware informations
