ATMEGA128-16AU Interface
Konusu 'Pic Uygulama Ve Devreleri' forumundadır ve guclusat tarafından 18 Eylül 2012 başlatılmıştır.
    New Solution Repair box JAF without resisters 330 and without remove chip LVC244A
    Step 1: You have to find a stem LPT port cable as shown:
    Just like on the Jack LPT port to attach to the back of the computer.
    And on what it has stated that Jack LPT number from 1 to 25 feet (see wealth in'll see). And we only care about 4 feet.
    No. 6 feet ..........( called SCK)
    No. 7 foot ..............( called Mosi)
    No. 9 feet ..............( called reset)
    foot No. 10 ............( called miso)
    As shown below:
    Step 2: Open Box JAF and welding as Figure 1 below.
    Step 3: View behind JAF BOX. using a scalpel and cut as shown in Figure 3 below.
    Step 4: Connect the USB for the JAF Box to use GND and 5V Voltage
    Step 5: Download: soft + Firmware of JAF box
    Step 6: Install PonyProg_V207c
    Step 7: After installation is complete, we set up as shown below.
    The steps to load and select the file you just need to conform to the video is 100% OK. The most important problem is the connection with JAF BOX LPT port only.
    Son düzenleme: 2 Eylül 2016
Benzer Konular - ATMEGA128 16AU Interface
