atmega128 schematic
Konusu 'Pic Uygulama Ve Devreleri' forumundadır ve guclusat tarafından 21 Mart 2013 başlatılmıştır.
    You must feel terible dissapointed if start asking what it's the power supply and the current that programmer use. Most of the peoples that uses Atmega128 never think about it as long as they carry on succesfuly with the usual programming procedure, either in serial or high voltage programming.
    As you probably know, the Atmel company developed an universal kit called STK500 and special extension board STK501 for Atmega128. These boards provides together a complete starter kit and development system for AVR micro.
    You can find more about them at Atmel site:
    STK500 user guide http://www.atmel.com/dyn/resources/p...ts/doc1925.pdf
    STK501 user guide (including schematics)
    http://www.atmel.com/dyn/resources/p...ts/DOC2491.PDF
    Special for you I attached the STK500 schematics, missing from user guide.
    Hope that clears your doubts regarding pin connections, power supply and xtal.
    Your interest regarding power supply and current that programmer should use it's a proove that don't hesitate to dig inside documentation if you are in trouble.
    Hope you have enough patience too.
Benzer Konular - atmega128 schematic
  5. uydudoktoru
