Audio Distribution Amplifier
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 3 Mayıs 2014 başlatılmıştır.
    The three channel output distribution amplifier uses a single LMX324. The first stage is capacitively coupled with a 1.0 µF capacitor. The inputs are at ½ VCC rail or 2.5 V. A voltage gain of 10 (1 MΩ/100 kΩ) is obtained in the first stage, and the other three stages are connected as unity-gain voltage followers. Each output stage independently drives an amplifier through the 50 µF output capacitor to the 5.1 kΩ load resistor. The response is flat from 10 Hz to 10 kHz.
    Son düzenleme: 30 Ağustos 2016
Benzer Konular - Audio Distribution Amplifier
  2. uydudoktoru
  4. uydudoktoru
