Basic flicker circuit
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 12 Kasım 2009 başlatılmıştır.
    Build a flicker circuit
    Electronic circuits to make lights flicker can be quite expensive. However, this circuit is easy to make and costs only a few dollars.
    The flicker effect will be caused by the erratic behavior of a thermal cutout switch in a fluorescent lamp starter. This circuit will work with lamps ranging from 7 to 40 watts. You can use more than one lamp so long as you do not exceed the wattage total.
    It is strongly recommended to put the starter into a metal electrical box because it will get hot.
    Below is a suggestion to make a reliable and safe connection to the terminals on the lamp starter.
    http://www.mediafire.com/?q655ry4z0d0ufj2
    Alternatif Link
    http://www.fileswap.com/dl/XykMJpxNzq/FIREFLICKER.zip.html
    Yukarda bir kaç örnek ekledim arkadaşlar zip içerisinde resimler ide pdf açıklamaları mevcuttur..
    Son düzenleme: 30 Eylül 2012
Benzer Konular - Basic flicker circuit
