BMW DTC Codes (Arıza kodları)
Konusu 'Elektronik Cihaz Katalog Bilgi Döküman Ve Dergiler' forumundadır ve guclusat tarafından 17 Ekim 2012 başlatılmıştır.
    P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1)
    P1084 Fuel Control Mixture Rich (Bank 1 Sensor 1)
    P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1)
    P1086 Fuel Control Mixture Rich (Bank 2 Sensor 1)
    P1087 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1)
    P1088 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1)
    P1089 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2)
    P1090 Pre-Catalyst Fuel Trim Too Lean Bank 1
    P1091 Pre-Catalyst Fuel Trim Too Rich Bank 1
    P1092 Pre-Catalyst Fuel Trim Too Lean Bank 2
    P1093 Pre-Catalyst Fuel Trim Too Rich Bank 2
    P1094 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1)
    P1095 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1)
    P1096 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1)
    P1097 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1)
    P1098 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2)
    P1111 Engine Coolant Temperature Radiator Outlet Sensor Low Input
    P1112 Engine Coolant Temperature Radiator Outlet Sensor High Input
    P1115 Coolant Temperature Sensor Plausibility
    P1116 Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2)
    P1117 Mass Or Volume Air Flow Circuit Low Input (Bank 2)
    P1118 Mass Or Volume Air Flow Circuit High Input (Bank 2)
    P1120 Pedal Position Sensor Circuit
    P1121 Pedal Position 1 Range/Performance Problem
    P1122 Pedal Position 1 Low Input
    P1123 Pedal Position 1 High Input
    P1132 O2 Sensor Heater Control Circuit (Bank 1 Sensor 1)
    P1133 O2 Sensor Heater Control Circuit (Bank 2 Sensor 1)
    P1134 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2)
    P1135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)
    P1136 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1)
    P1137 O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2)
    P1138 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
    P1139 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2)
    P1140 Mass or Volume Air Flow Circuit Range/Performance Problem
    P1145 Solenoid Valve Running Losses Control Circuit Electrical
    P1151 O2 Sensor Heater Circuit Signal Intermittant (Bank 2 Sensor 1)
    P1152 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1)
    P1153 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1)
    P1155 O2 Sensor Heater Circuit Intermittant (Bank 2 Sensor 2)
    P1156 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2)
    P1157 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2)
    P1158 Fuel Trim Additve Bank 1 Low
    P1159 Fuel Trim Additve Bank 1 High
    P1160 Fuel Trim Additve Bank 2 Low
    P1161 Fuel Trim Additve Bank 2 High
    P1162 Fuel Trim Additve Per Ignition Bank 1 Low
    P1163 Fuel Trim Additve Per Ignition Bank 1 High
    P1164 Fuel Trim Additve Per Ignition Bank 2 Low
    P1165 Fuel Trim Additve Per Ignition Bank 2 High
    P1174 Fuel Trim Adaptation Additve Bank 1 Malfunction
    P1175 Fuel Trim Adaptation Additve Bank 2 Malfunction
    P1176 O2 Sensor Slow Response Bank 1
    P1177 O2 Sensor Slow Response Bank 2
    P1178 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 1)
    P1179 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 1)
    P1180 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 1 Sensor 2)
    P1181 O2 Sensor Signal Circuit Slow Switching From Rich to Lean (Bank 2 Sensor 2)
    P1182 O2 Sensor (Bank 1 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
    P1183 O2 Sensor (Bank 2 Sensor 2) Open Circuit During Coast Down Fuel Cut-off
    P1186 O2 Sensor Heater Control Circuit (Bank 1 Sensor 2)
    P1187 O2 Sensor Heater Control Circuit (Bank 2 Sensor 2)
    P1188 Fuel Control (Bank 1 Sensor 1)
    P1189 Fuel Control (Bank 2 Sensor 1)
    P1190 Pre-catalyst Fuel Trim System Bank 1
    P1191 Pre-catalyst Fuel Trim System Bank 2
    P1192 Post-catalyst Fuel Trim System Bank 1
    P1193 Post-catalyst Fuel Trim System Bank 2
    P1221 Pedal Position Sensor 2 Range/Performance Problem
    P1222 Pedal Position Sensor 2 Low Input
    P1223 Pedal Position Sensor 2 High Input
    P1270 Control Module Self-Test, Torque Monitoring
    P1271 Ambient Air Pressure Sensor Electrical
    P1283 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Electrical
    P1284 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal Low
    P1285 Switching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Signal High
    P1287 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Electrical
    P1288 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low
    P1289 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High
    P1313 "A" Camshaft Position Plausibility
    P1317 "B" Camshaft Position Plausibility
    P1327 Knock Sensor 2 (Bank 1) Low Input
    P1328 Knock Sensor 2 (Bank 1) High Input
    P1332 Knock Sensor 4 Low Input
    P1333 Knock Sensor 4 High Input
    P1340 Multiple Cylinder Misfire During Start
    P1341 Multiple Cylinder Misfire With Fuel Cut-off
    P1342 Misfire During Start Cylinder 1
    P1343 Misfire Cylinder 1 With Fuel Cut-off
    P1344 Misfire During Start Cylinder 2
    P1345 Misfire Cylinder 2 With Fuel Cut-off
    P1346 Misfire During Start Cylinder 3
    P1347 Misfire Cylinder 3 With Fuel Cut-off
    P1348 Misfire During Start Cylinder 4
    P1349 Misfire Cylinder 4 With Fuel Cut-off
    P1350 Misfire During Start Cylinder 5
    P1351 Misfire Cylinder 5 With Fuel Cut-off
    P1352 Misfire During Start Cylinder 6
    P1353 Misfire Cylinder 6 With Fuel Cut-off
    P1354 Misfire During Start Cylinder 7
    P1355 Misfire Cylinder 7 With Fuel Cut-off
    P1356 Misfire During Start Cylinder 8
    P1357 Misfire Cylinder 8 With Fuel Cut-off
    P1358 Misfire During Start Cylinder 9
    P1359 Misfire Cylinder 9 With Fuel Cut-off
    P1360 Misfire During Start Cylinder 10
    P1361 Misfire Cylinder 10 With Fuel Cut-off
    P1362 Misfire During Start Cylinder 11
    P1363 Misfire Cylinder 11 With Fuel Cut-off
    P1364 Misfire During Start Cylinder 12
    P1365 Misfire Cylinder 12 With Fuel Cut-off
    P1384 Knock Sensor 3 Circuit
    P1385 Knock Sensor 4 Circuit
    P1386 Control Module Self-test, Knock Control Baseline Test Bank 1
    P1396 Crankshaft Position Sensor Segment Timing Plausibility
    P1397 Camshaft Position Sensor "B" Circuit (Bank 1)
    P1400 Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)
    P1401 Heated Catalyst Current too High During Heating (Bank 1)
    P1402 Heated Catalyst Power Switch Overtemperature Condition (Bank 1)
    P1403 Carbon Canister Shut Off valve Control Circuit Electrical
    P1404 Heated Catalyst Current too High During Heating (Bank 2)
    P1405 Heated Catalyst Power Switch Overtemperature Condition (Bank 2)
    P1406 Heated Catalyst Internal Control Module Checksum/ROM Error
    P1413 Secondary Air Injection Pump Relay Control Circuit Signal Low
    P1414 Secondary Air Injection System Monitor Circuit High
    P1420 Secondary Air Valve Control Circuit Electrical
    P1421 Secondary Air System Bank 1
    P1422 Secondary Air System Bank 2
    P1432 Secondary Air Injection System Incorrect Flow Detected
    P1438 Purge Control Valve Control Open Circuit
    P1439 Purge Control Valve Control Circuit Signal Low
    P1440 Purge Control Valve Control Circuit Signal High
    P1441 Leakage Diagnostic Pump Control Open Circuit
    P1442 Leakage Diagnostic Pump Control Circuit Signal Low
    P1443 Leakage Diagnostic Pump Control Circuit Signal High
    P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit
    P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low
    P1446 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High
    P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching
    P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching
    P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Too High
    P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit
    P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low
    P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High
    P1453 Secondary Air Injection Pump Relay Control Circuit Electrical
    P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical
    P1456 Heated Catalyst Heater Power Supply Open Circuit (Bank 1)
    P1457 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 1)
    P1459 Heated Catalyst Heater Power Supply Open Circuit (Bank 2)
    P1460 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2)
    P1461 Heated Catalyst Gate Voltage Signal Low
    P1462 Heated Catalyst Internal Control Module Checksum/ROM Error
    P1463 Heated Catalyst Battery Temperature Sensor 1 Electrical
    P1464 Heated Catalyst Battery Temperature Sensor 2 Electrical
    P1465 Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility
    P1466 Heated Catalyst Power Switch Temperature Sensor Plausibility
    P1467 Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility
    P1468 Heated Catalyst Battery Disconnecting Switch Plausibility
    P1470 Leakage Diagnostic Pump Control Circuit Electrical
    P1472 Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical
    P1473 Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility
    P1475 Leakage Diagnostic Pump Reed Switch Did Not Close
    P1476 Leakage Diagnostic Pump Clamped Tube
    P1477 Leakage Diagnostic Pump Reed Switch Did Not Open
    P1500 Idle Speed Control Valve Stuck Open
    P1501 Idle Speed Control Valve Stuck Closed
    P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or
    Low
    P1503 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low
    P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit
    P1505 Idle Speed Control Valve Closing Solenoid Control Circuit Electrial
    P1506 Idle Speed Control Valve Open Solenoid Control Circuit Signal High
    P1507 Idle Speed Control Valve Open Solenoid Control Circuit Signal Low
    P1508 Idle Speed Control Valve Opening Solenoid Control Open Circuit
    P1509 Idle Speed Control Valve Opening Solenoid Control Circuit Electrial
    P1510 Idle Speed Control Valve Stuck
    P1511 DISA Control Circuit Electrical
    P1512 DISA Control Circuit Signal Low
    P1513 DISA Control Circuit Signal High
    P1519 "A" Camshaft Position Actuator Bank 1
    P1520 "B" Camshaft Position Actuator Bank 1
    P1522 "A" Camshaft Position Actuator Bank 2
    P1523 "A" Camshaft Position Actuator Signal Low Bank 1
    P1524 "A" Camshaft Position Actuator Signal High Bank 1
    P1525 "A" Camshaft Position Actuator Control Open Circuit Bank 1
    P1526 "A" Camshaft Position Actuator Control Open Circuit Bank 2
    P1527 "A" Camshaft Position Actuator Control Circuit Signal Low Bank 1
    P1528 "A" Camshaft Position Actuator Control Circuit Signal High Bank 1
    P1529 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 1
    P1530 "B" Camshaft Position Actuator Control Circuit Signal High Bank 1
    P1531 "B" Camshaft Position Actuator Control Open Circuit Bank 1
    P1532 "B" Camshaft Position Actuator Control Open Circuit Bank 2
    P1533 "B" Camshaft Position Actuator Control Circuit Signal Low Bank 2
    P1534 "B" Camshaft Position Actuator Control Circuit Signal High Bank 2
    P1540 Pedal Position Sensor
    P1541 Pedal Position Sensor Double Error
    P1542 Pedal Position Sensor Electrical
    P1543 Pedal Position Sensor
    P1544 Pedal Position Sensor
    P1545 Pedal Position Sensor
    P1546 Pedal Position Sensor
    P1550 Idle Speed Control valve Closing Solenoid Control Circuit Electrical
    P1551 "A" Camshaft Position Actuator Control Open Circuit Bank 1
    P1552 "A" Camshaft Position Actuator Control Open Circuit Bank 1
    P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1
    P1560 "B" Camshaft Position Actuator Control Open Circuit Bank 1
    P1564 Control Module Selection
    P1565 "B" Camshaft Position Actuator Control Open Circuit Bank 1
    P1569 "A" Camshaft Position Actuator Control Open Circuit Bank 2
    P1580 Throttle Valve Mechanically Stuck
    P1581 "B" Camshaft Position Actuator Control Open Circuit Bank 2
    P1589 Control Module Self Test, Knock Control Test Pulse Bank 1
    P1593 DISA Control Circuit Electrical
    P1594 "B" Camshaft Position Actuator Control Open Circuit Bank 2
    P1602 Control Module Self Test, Control Module Defective
    P1603 Control Module Self Test, Torque Monitoring
    P1604 Control Module Self Test, Speed Monitoring
    P1607 CAN Version
    P1608 Serial Communicating Link Control Module
    P1609 Serial Communicating Link EML
    P1611 Serial Communicating Link Transmission Control Module
    P1619 MAP Cooling Control Circuit Signal Low
    P1620 MAP Cooling Control Circuit Signal High
    P1622 MAP Cooling Control Circuit Electrical
    P1623 Pedal Position Sensor Potentiometer Supply
    P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical
    P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical
    P1632 Throttle Valve Adaptation; Adaptation Condition Not Met
    P1633 Throttle Valve Adaptation; Limp Home Position
    P1634 Throttle Valve Adaptation; Spring Test Failed
    P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted
    P1636 Throttle Valve Control Circuit
    P1637 Throttle Valve Position Control; Control Deviation
    P1638 Throttle Valve Position Control; Throttle Stuck Temporarily
    P1639 Throttle Valve Position Control; Throttle Stuck Permanently
    P1640 Internal Control Module (ROM/RAM) Error
    P1690 Malfunction Indicator Lamp (MIL) Electrical
    P1734 Pressure Control Solenoid "B" Electrical
    P1738 Pressure Control Solenoid "C" Electrical
    P1743 Pressure Control Solenoid "E" Electrical
    P1744 Pressure Control Solenoid "A" Electrical
    P1746 Transmission Control Module Output Stage
    P1747 CAN Bus Monitoring
    P1748 Transmission Control Module Self Test
    P1749 Secondary Pressure Solenoid Communication Error
    P1750 Secondary Pressure Solenoid Circuit Range/Performance
    P1751 Secondary Pressure Solenoid Open Circuit
    P1761 Shift Solenoid Malfunction
    P1765 CAN Throttle Valve
    P1770 CAN Torque Interface
    P1780 CAN Torque Reduction
Benzer Konular - BMW DTC Codes
