charge a 48volt battery bank from 12v battery or solar panel
Konusu 'Smps Devreleri Ve Uygulamaları' forumundadır ve uydudoktoru tarafından 23 Şubat 2015 başlatılmıştır.
    Most of the time we need to convert a 12volt dc to 48volt dc to charge a 48 volt battery bank from 12volt battery or even solar panel. So in this post we are going to learn how to make a 12v dc to 48volt dc converter or boost convert using timer IC-555 (readily available, cheap and always will be in production) using readily available parts from market.
    This 12v to 48 volt converter circuit or boost converter is a DC to DC converter using the property of intuctor to oppose the rate of change of current through it. This transformerless electronic power supply circuit uses a timer IC-555 to operate in astable mode and this transformerless electronic power supply circuit have an output frequency of around 600Hz at 58% duty cycle.
    This project is similar to 12v to 48 volt converter but have more stable and regulated output .
    Component required:-
    R1 - 4 kilo-ohms 1/4W
    R2 - 10 kilo-ohms 1/4W resistor
    R3 - 10 kilo-ohms 1/4W
    R4 - 2.2 kilo-ohms 1/4W
    R5 - 2.5 kilo-ohms 1/4W
    R6 - 120 ohms 1W
    C1 - 100nF
    C2 - 100nF
    C3 - 1000uF rated 50V or higher
    C4 - 1000uF rated 16V or higher
    D1 - 1N5401 or any diode rated 3A or higher
    D2 - 1N4756A,1N5368B or 47V zener
    D3 - 1N4740A, 1N5346B or any 8.2V to 9.1V zener
    D4 - 1N4001 or similar
    Q1 - IRF530 N-chanel MOSFET
    Q2 - 2n3055
    L1 - 40 turns #22AWG magnet wire in antenna rod
    LED - 3mm to 5mm any color LED
    555 IC
    Circuit diagram:
    12V DC TO 48V DC CONVERTER TO CHARGE A 48VOLT BATTERY BANK FROM 12 VOLT BATTERY OR SOLAR PANEL
