Danish Amateur Frequencies
Konusu 'Fm Verici Devreleri' forumundadır ve uydudoktoru tarafından 26 Mayıs 2015 başlatılmıştır.
    Class A Licence: (Passed test 1+2+3)
    135.7 - 137.8 KHz (1W)
    1.810 - 1.850 MHz 160m
    1.850 - 1.900 MHz 160m (10w)
    1.930 - 2.000 MHz 160m (10w)
    3.500 - 3.800 MHz 80m
    7.000 - 7.200 MHz 40m
    10.100 - 10.150 MHz 30m
    14.000 - 14.350 MHz 20m
    18.068 - 18.168 MHz 17m
    21.000 - 21.450 MHz 15m
    24.890 - 24.990 MHz 12m
    28.000 - 29.700 MHz 10m
    50.000 - 52.000 MHz 6m
    70.0125 - 70.0625 MHz 4m (25W)
    70.0875 - 70.1125 MHz 4m (25W)
    70.3125 - 70.3875 MHz 4m (25W)
    70.4125 - 70.4875 MHz 4m (25W)
    144.00 - 146.00 MHz 2m
    432.00 - 438.00 MHz 70cm
    1240 - 1300 MHz 23cm
    2300 - 2450 MHz
    3400 - 3410 MHz
    5650 - 5850 MHz
    10.0 - 10.5 GHz
    24.0 - 24.25 GHz
    47.0 - 47.2 GHz
    75.5 - 81.0 GHz
    122.25 - 123 GHz
    134 - 141 GHz
    241 - 250 GHz
    Max power is 1000 Watt, unless other stated. At frek over 1GHz, max power is 250 Watt.
    Class B Licence: (passed test 1+2)
    All bands like class A, but Max power is 100 Watt, except 4m
    Class D Licence: (Passed test 1, Easy multi-choise test)
    50.000 - 52.000 MHz 6m (50W)
    144.00 - 146.00 MHz 2m (50W)
    432.00 - 438.00 MHz 70cm (50W)
    1240 - 1300 MHz 23cm (50W)
    To calculate actual wave length in meters:
    300/freq mhz = meters. eks: 300/14.2 = 21.12 meters
    Quarterwave wire antennas, each of the two wires is this length:
    (75/freq mhz) * 0.9 = meters. eks: 75/14.2 = 5.28 * 0.9 = 4.75 meters.
