Dreambox dm100 yazılımları:
Konusu 'Dreambox' forumundadır ve ELMADAĞLI tarafından 4 Temmuz 2009 başlatılmıştır.
  1. ELMADAĞLI
    ELMADAĞLI Tanınmış Üye Kayıtlı Üye
    18 Haziran 2009
    Son düzenleme: 4 Temmuz 2009
  2. ELMADAĞLI
    18 Haziran 2009
    DM 100 ÖZELLİKLERİ VE RESİMLERİ
    MPEG-2 hardware decoding
    2 x LED - status
    1 x Smartcard-Reader
    1 x Scart
    1 x S-Video
    10/100Mbit compatible Ethernet Interface
    USB-B
    S/PDIF Interface for digital bit stream out (AC-3)
    unlimited channel lists for TV/Radio
    channel-change time < 1 second
    full automatic service scan
    directly bouquet-lists
    EPG (electronic program guide)
    own videotext and subtitle
    multiple LNB-Switching control (DiSEqC)
    fully adaptable OSD in many languages
    Picture in Picture (PIP) and Picture in graphics (PIG)
    Zoom function
    DreamBox DM100 technical data DBS-Tuner:
    Frequency Range 950 …. 2150 MHz
    Signal Level - 65 dBm …. - 25 dBm
    Signal-to-Noise Level 12 dB max.
    DBS-Tuner Input Connector F-Type female
    Input Impedance 75 Ohm
    AFC +/- 3 MHz
    Demodulation Shaped QPSK
    FEC Viterbi and Reed-Solomon
    Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8
    Roll-off Factor 35 %
    Demultiplexing according ISO 13818-1
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible
    Video Standard PAL G/ 25 Hz
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II
    Audio Mode Dual (main/sub), Stereo
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical (AC3)
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, RGB
    USB:
    USB 1.22:
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    LNB Power and polarisation:
    LNB Current 500mA max. ; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    LNB shut-off at Standby-Mode
    Count of active satellite position:
    DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
    DiSEqC - Rotor Control
    Power consumption:
    < 10W / 12V
    Input voltage:
    DC12V +/- 15%
    Extern power supply:
    Input: 110-240V AC / 50-60Hz / 0,6A
    Output: 12V = / 1A or 2A
    Physical specification:
    Ambient Temperature +15°C...+35°C
    Humidity < 80%
    Size (W x D x H): 195 mm x 130 mm x 30 mm
    Weight: 540 g
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  3. ELMADAĞLI
    18 Haziran 2009
    Dm 100 menü resimleri:
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  4. ELMADAĞLI
    18 Haziran 2009
  5. ibrahimyzci
    ibrahimyzci Moderator
    16 Haziran 2009
    eline sağlık teşekkürler...
  6. deknosman
    deknosman Yeni Üye Kayıtlı Üye
    16 Aralık 2009
    Yazılım için teşekkürler de benim cihazdaki kanalları bilgisayara yedekleyip bilgisayarda düzenledikten sonra tekrar cihaza attım cihaz açılmıyor.cihaz üzerinde açma/kapama tuşuna basınca panelddeki ışık yeşilden kırmızıya dönüyor(veya tersi) çihaz açılmıyor. pc görüyor cihazı. yardımcı olabilecek varmı.
Benzer Konular - Dreambox dm100 yazılımları
  5. oohayaletoo
