DREAMBOX DM800 HD PVR tüm imajlar:
Konusu 'Dreambox' forumundadır ve ELMADAĞLI tarafından 4 Temmuz 2009 başlatılmıştır.
  1. ELMADAĞLI
    ELMADAĞLI Tanınmış Üye Kayıtlı Üye
    18 Haziran 2009
    DREAMBOX
    DM800 HD PVR
  2. ELMADAĞLI
    18 Haziran 2009
    30/06/09PLi Jade3
    08/05/09PLi Jade2 (update) 31/03/09PLi Jade2 (update) 28/12/08PLi Jade2 31/10/08PLi Jade Final Images Suite (update)
    01/10/08PLi Jade Final Images Suite
    18/07/08PLi Jade 12/05/08PLi Iolite May 2008 Edition
    25/06/09DreamForum II v10.2
    06/06/09DreamForum II v10.0
    19/08/08DreamForum II v6.0
    21/06/09LS ENIGMA2 IMAGE 20090621 13/05/09LS ENIGMA2 IMAGE 20090513 25/04/09LS ENIGMA2 IMAGE 20090425 22/02/09LS ENIGMA2 IMAGE 20090222 29/01/09LS ENIGMA2 IMAGE 20090129 23/11/08LS ENIGMA2 IMAGE 20081122
    20/10/08LS ENIGMA2 IMAGE v.2.2
    15/06/09Gemini2 v4.30 23/04/09Gemini2 v4.20 07/02/09Gemini2 v4.10 02/01/09Gemini2 v4.00 30/11/08Gemini2 v3.90 27/09/08Gemini2 v3.80 28/07/08Gemini2 v3.70
    20/06/08Gemini2 v3.60 22/05/08Gemini2 v3.50
    30/05/09NewNigma² 2.5.2
    16/05/09NewNigma² 2.5 21/03/09NewNigma² 2.4 22/02/09NewNigma² 2.3.2
    28/01/09NewNigma² 2.3.1
    25/12/08NewNigma² 2.3 01/11/08NewNigma² 2.2.1 05/10/08NewNigma² 2.2 17/07/08NewNigma² 2.1.2
    23/06/08NewNigma² 2.1.1 16/06/08NewNigma² 2.1 13/05/08E² - Board Image 2.01
    30/05/09LT - The Fifth Campaign SP7 Final Edition 07/03/09LT - The Fifth Campaign SP6
    31/01/09LT - The Fifth Campaign SP5
    15/11/08LT - The Fifth Campaign SP4
    07/07/08LT - The Fifth Campaign
    03/05/09Nabilosat Enigma2 Black Hole 0.10
    25/02/09Nabilosat Enigma2 Black Hole 0.9
    18/01/09Nabilosat Enigma2 Black Hole 0.7
    02/01/09Nabilosat Enigma2 Black Hole 0.6
    11/12/08Nabilosat Enigma2 Black Hole 0.5
    13/07/08Nabilosat Enigma2 Black Hole 0.3
    11/06/08Nabilosat Enigma2 Black Hole 0.2b
    05/06/08Nabilosat Enigma2 Black Hole RC1
    27/04/09EDG-Nemesis 1.0 RC1
    17/02/09Peter Pan Neverland 1.3 E2
    02/10/08Peter Pan Neverland 1.2.1 E2
    20/06/08Peter Pan Neverland 1.1 E2
    06/01/09DS² 2.0
    FIRMWARE ORIGINALI CON CVS AGGIORNATO PER DM80003/05/09Nabilosat Enigma2 Pure Flash 02MAY09
    25/02/09Nabilosat Enigma2 Pure Flash 25FEB09
    11/12/08Nabilosat Enigma2 Pure Flash 11DEC08
    21/05/08EDG-Nemesis Perfect Flash Plus v.1.2
    16/05/08EDG-Nemesis Perfect Flash Plus v.1.1
    06/05/08EDG-Nemesis Perfect Flash Plus v.1.0
    12/04/08OoZooN CVS DM800 HD PVR
    FIRMWARE ORIGINALI PER DM80001/05/08Firmware Originale Release 1.0
  3. ELMADAĞLI
    18 Haziran 2009
    New
    MyTube plugin: this plugin has been included by default.
    Enigma2 CVS date
    29 June 2009 2.6 experimental
    Drivers date
    30 June 2009
    Second Stage #73-pr0
    Main Function ****
    Button 1xOK = Light Info Skin
    Button 2xOK = Extra Info Skin
    Button Blue = Nabilo Blue Panel
    Button 1x Blue + 1x Yellow = New System Monitor Panel
    Button Blue-Long-Push = Extensions
    Button Green = Nabilo Green Panel
    Button Green-Long-Push = Subservices
    Button 1x Green + 1x Red = CCcam Info
    Button Red = Start Record
    Button Yellow = Time Shift
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    Enigma2 Analogic Clock
    Channel Orbital Position
    Advanced Tuner Info: Sr Freq Pol Fec
    Signal SNR, BER
    Infobar Picons
    LCD/OLED Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Setup
    Black Hole Cron Manager
    Black Hole EPG Panel
    OSD Settings
    Devices Manager
    Kernel Modules Manager
    LCD Settings
    Fast Plugin Settings
    Inadyn Settings
    Swap File Settings
    Hard Disk Setup
    Nabilo Mount Wizard
    OpenVPN Panel
    Samba/Cifs Panel
    NFS Server Panel
    Telnet Panel
    FTP Panel
    CCcam Info
    Service Info
    Enigma2 Settings
    About
    Memory
    Space
    CPU
    Process
    AutoCam
    Select EMU by Channel
    2) Green Panel
    CCcam Info
    Fast Plugin
    Addons
    Addons Download Manager
    Manual Install Nab packages
    Manual Install IPK packages
    Addons Uninstall Panel
    Nabilosat Statistics
    Scripts
    Many thanks to the Beta Testers Team
    Credits
    E2 Sky Epg loader integration by MaxZ4.
    Matrix10 for the new Black&White HD skin.
    Many Thanks to lukkino (VDR-Italia) for opentv source code.
    This Images doesn't contain any **** nor softcams.
    Backups or other modified Images are not supported!
    Nabilosat Enigma2 Black Hole - DM800 v0.11 İNDİR
  4. ELMADAĞLI
    18 Haziran 2009
    What is new in this version 0.11 ?
    Matrix10 Black&White HD Skin awesome HD skin with large size fonts and panels
    Nabilosat Black Hole Device Manager gives you full control over all your connected media: USB, CF, SD, HDD, DVD
    Nabilosat Black Hole Kernel Modules Manager allows you to setup all the modules required by additional features and devices
    Nabilosat Black Hole AutoCam allows you to assign a different CAM/EMU to each channel
    NTFS support allows you to mount a device formatted to Windows NTFS
    Smargo Phoenix & others Usb Card Readers enable your Smargo or other USB Card Readers, based on chipsets Ftdi and Pl2303
    Virtual Keyboard is a new CVS feature enabling you to type in data through an on screen keyboard
    Viasat EPG is now available for download
    Subtitles White Large Fonts TXT subtitles with HD skins. Large DVB subtitles HD full size (CVS last fix)
    New:
    Nabilosat Black Hole Device Manager: this system will scan your DM for connected media, such as USB ****, CF, SD, HDD, DVD, and automatically identify them. Once identified, each media can be formatted, mounted and unmounted. Thus, you are no longer required to run a script or a command line to install any external memory device. Nabilosat Black Hole will handle this for you.Press 2x Blue, and select Black Hole Device Manager
    New:
    Nabilosat Black Hole Kernel Modules Manager: this new feature allows you to control the kernel modules, to support the NTFS file system, and enable the Smargo as well as other USB Card Readers, Ftdi and Pl2303 chipset based. If there are features you are not using, such as OpenVPN or NFS server, then you can disable their modules. Disabling unused modules will optimize your memory usage. The Kernel Module panel provide too an useful function to show all the kernel modules current running on your dreambox and relative size and informations. Press 2x Blue for the Kernel Modules Manager
    New:
    Nabilosat Black Hole AutoCam: this new feature allows you to use a different CAM/EMU for each channel. When you zap, Nabilosat Black Hole API system will handle the different EMU, and start the selected one. To assign an EMU to a channel, zap to the channel, press 1x Blue, and 1x Green
    New:
    CVS Virtual Keyboard: introduced by the CVS, this new feature offers an alternative solution to enter data where required. Nabilosat Team chose to use the Virtual Keyboard for the CCcam Setup, Inadyn Setup, Cron Manager custom command
    New
    Skin Matrix10 Black&White: awesome HD skin with large size fonts and panels
  5. ELMADAĞLI
    18 Haziran 2009
  6. ALBAYCEYHUN
    ALBAYCEYHUN Guest
    teşekürler
  7. munur
    munur Üye Kayıtlı Üye
    24 Haziran 2009
    sekurler saolun
  8. watcherr
    watcherr Üye Kayıtlı Üye
    16 Temmuz 2009
    teşekkürler
Benzer Konular - DREAMBOX DM800 PVR
  1. ELMADAĞLI
