DreamBoxEdit-IHAD Edition 3.1.0.1
Konusu 'Dreambox Tools/Editors' forumundadır ve guclusat tarafından 17 Eylül 2010 başlatılmıştır.
    Changelog:
    3.1.0.1
    - fixed problem with bouquet selection panel
    - added selectable picon format (100x60, 71x53, 70x53)
    - added autoresize for picons if format doesn't match selection
    - now uses another library for picons to speedup picon loading
    3.1.0.0
    - fixed problem when using cut and paste with cable or terrestrial services
    - fixed cut and paste which filled empty fields with 0
    - fixed compare function, the internal service counter wasn't reset when the operation was canceled
    - fixed a problem when option "show all service details in the services list" was disabled
    - fixed error message when rolloff or pilot is missing in lamedb for DVB-S2 transponders
    - fixed namespace calculation for Enigma2
    - fixed error message in details and transponder edit window with Enigma1 settings
    - fixed bouquets.tv and bouquets.radio which are now written in proper settings-type 4 format
    - disabled renaming of markers, use the edit marker text option in context menu
    - improved satellites.xml update
    - added full Engima2 alternatives support
    - added option "Don't save backup files" (this option will also remove existing backups from save directory)
    - added cleanup function for save directory which removes all unneeded files
    - added display of reference picons (format 71x53) in bouquets and in service details window
    - added option to enable/disable picons in bouquets panel
    3.0.3.0
    - DVB-C symbolrate is now displayed in main window
    - all frequencies in the main window are now displayed in MHz
    - all symbolrates in the main window are now displayed in well known formats
    e.g. for satellite 27500 instead of 27500000, for cable 6900 instead of 6900000
    - added support for "new channel" flag of your dreambox (flag can be set or removed in service details)
    Note: There are two different new channel flags
    the first the one is the old "New" flag (now "X") which is set when using "Mark services not in Userbouquets with X"
    the second one is the "N" flag which is set by your dreambox when a new channel is found by the service scan
    - added option to remove all "N" and "X" flags in tools menu
    - changed option in context menu to remove "N" and "X" flags from selected services
    - fixed problems when using the compare functions
    - fixed problem with missing DVB-system and modulation when using cut and paste
    - fixed problem when removing empty markers
    - added support for parameter c:09 (subtitle) for Enigma1
    - finally fixed missing scrollbar issue
    3.0.2.0
    - added DVB-S2 transponder data editing
    - added DVB-S2 export/import
    - added support for circular polarisation
    - fixed re-import of exported services and bouquet files
    - fixed export of renamed services
    - fixed satellites.xml update function
    - fixed some missing translations
    - language files updated
    - code cleanup
    3.0.1.7
    - fixed problem with user bouquet import
    - support for Enigma2 user bouquet parental lock
    - small GUI fixes
    3.0.1.6
    - after changing service type to TV, the text still showed the old service type
    - fixed wrong bouquet type flag for radio bouquets
    - filter for DVB-S/DVB-S2 added
    3.0.1.5
    - automatic renaming of invalid bouquets on Enigma2->Enigma1 conversion
    - support for Enigma2 alternative services (only download/upload)
    - added confirmation question before modification of satellites.xml
    - display of currently active service is now disabled by default, but can be enabled in options panel
    (Note: if you experience any problems when running DreamBoxEdit and your Dreambox is offline, just disable that option again)
    3.0.1.4
    - fix for satellites.xml with twisted parameters
    - fixed gui for low resolutions
    - some language file updates
    3.0.1.3
    - fixed problem with FTP mode, Quick FTP commands were sent
    - fixed problem with Quick FTP mode, now standard reload command is sent instead of killall -9 enigma2
    - fixed problem with directory selection window, now it always jumps to the last used directory
    - small GUI changes
    3.0.1.2
    - fixed overlapping text in translated popup menus
    - fixed some not translated shortcuts in popup menus
    - fixed language files
    - fixed error message when uploading settings without opening them before
    - another network timeout fix
    - option to deactivate automatic display of currently active service and volume control
    - optional use of the old window style, if you remove/rename DreamBoxEdit.exe.manifest from install folder
    - improved satellites.xml editor, now fully functional editing for enigma2 and synchronisation with loaded settings
    3.0.1.1
    - fixed network timeout issue when IP address is not reachable
    - fixed editing and saving of negative AC3 and PCM delays
    (note: you have to delete all extra parameters in the detail panel if you have entered any delay values before)
    - fixed error message after saving and opening new settings
    - added customizable row color
    - new window and button styles
    - all message dialog buttons were german, message dialogs can't be translated, changed locale to English
    3.0.1.0
    - added display of currently active service on your dreambox (enigma2 only)
    - added volume control (enigma2 only)
    - added malti language file, other language files updated
    - fixed error message when comparing loaded services with services on dreambox/disk
    - added button for special services (service types 130, 133 and 211) in the options panel
    (you need a patched Channelselection.py to make this channels visible on Enigma2)
    - added service type 10 to standard radio types
    - small GUI changes
    3.0.0.6
    - disabled SatcoDX import/export as this feature is deprecated, website of SatcoDX is down
    - improved servicename filter, now it matches all services, the old one missed some (e.g. RTL Television on 19.2°E)
    - sorting of columns with drag&drop is now possible (no saving at the moment)
    - fixed update check
    - added column for DVB-system
    - added column for modulation (now it's possible to remove all DVB-S2 transponders after conversion from E2 to E1 very easily)
    3.0.0.5
    - removed settings-type 3 from options panel (no longer needed all E2-Boxes working with settings-type 4)
    - added button with terrestrial path settings (E1) to options panel
    - fixed settings-type switching via menu -> tools -> toggle between version 2 and 4 settings
    - added language files (crnogorski, czech, dansk, espanol, francais, greek, hrvatski, italiano, magyar,
    nederlands, norsk, polish, russian, srpski, svenska, turkce, ukrainian)
    - added language tool for translations (you can find it in the installation folder),
    please send me your language file updates on the support forum, thanks!
    3.0.0.4
    - fixed error message after enigma2 settings reload
    - servicename filter added
    3.0.0.3
    - fixed scrollbar issue
    3.0.0.2:
    - restored zap function for enigma2
    - changed menu bar icons
    3.0.0.1:
    - fixed FEC values for DVB-S/DVB-S2 modes
    - restored satellites.xml editor function
  2. zubo09
    zubo09 Yeni Üye Kayıtlı Üye
    25 Aralık 2009
    teşekkürler kardeş
