Electronic Doorbell Light Schematic
Konusu 'Elektronik Devreler' forumundadır ve uydudoktoru tarafından 4 Şubat 2011 başlatılmıştır.
    This 6V battery operated doorbell light circuit can be connected in parallel with any existing AC230V doorbell. When anyone push the doorbell switch, the bell sounds as usual and ac mains supply available across the doorbell is routed to the input of this circuit through an opto-coupler(IC1).
    Conduction of IC1 triggers a monostable, wired around the good old 555 timer (IC2). As a result the high-bright white LED (D2) at the output of IC2 is switched on for a short time. This circuit is highly useful at night/midnight as it gives sufficient indoor light to help you locate switches for room lamp/porch light, etc. On/Off duration of the LED light can be increased/decreased by increasing/decreasing the value of C2.
    The electronic doorbell light circuit is fully safe because it is perfectly isolated from the fatal ac mains supply by IC1. However, keep to avoid accidental contacts with the front end of the circuit, which is directly connected to the ac supply. Use of a good and convenient ABS enclosure is recommended for this doorbell light unit.
    Electronic Doorbell Light Circuit Schematic
    Son düzenleme: 22 Nisan 2015
Benzer Konular - Electronic Doorbell Light
  4. uydudoktoru
  5. uydudoktoru
