FAN7554 SMPS Devresi (The Output Adjustable Flyback Converter)
Konusu 'Smps Devreleri Ve Uygulamaları' forumundadır ve guclusat tarafından 15 Mart 2010 başlatılmıştır.
    Design Guidelines
    DCM mode, output power is 200W
    The input RMS current in worse condition with discontinuous current mode may be calculated as:
    If the optimum operating duty cycle is set at D=0.35, then input peak current can be found as:
    Therefore the voltage sensing limit voltage level from the FAN7554 data sheet is 1.5V
    Son düzenleme: 24 Ocak 2017
