Ferguson Ariva HD Cihaz Tanıtımı
Konusu 'Diğer Uydu Alıcıları' forumundadır ve guclusat tarafından 10 Ekim 2009 başlatılmıştır.
    Ferguson Ariva HDcombo
    Detalles tecnicos
    • Receives satellite and terrestrial High Definition channels
    • USB PVR function with TimeShift
    • PAL upscaling up to 720p & 1080i resolution
    • Dolby Digital surround audio
    • Card reader for pay TV and 2 Common Interfaces
    • Up to 8000 channels
    • Supports timers
    • Favorite channel groups, TV and radio
    • Electronic Program Guide (EPG)
    • QuickFind function
    • Supports Teletext and Subtitles
    • Multilanguage menu (OSD)
    • Pre-programmed channel list
    • DiSEqC 1.0 and USALS support
    • MPEG-2, MPEG-4, MPEG-4 AVC/H.264 support
    • Fully compliant with DVB-T, DVB-S and DVB-S2
    • Alphanumeric VFD display (8 characters)
    • Software upgrade via USB port
    • High Definition menu (HD OSD)
    • Audio files player
    • Photo viewer
    • Controllable through standard RCU or universal RCU-600
    Connectors:
    • HDMI with HDCP
    • USB 2.0
    • Component (Y, Pb, Pr)
    • 2x SCART
    • CVBS - RCA (Cinch) video
    • 2x RCA (Cinch) analog audio
    • Optical digital audio output TOSLINK
    Dimensions (W x D x H): 358x257x63 mm
    Net weight: 3 kg
    Ariva 200-HD
    Ariva 200 is an excellent image quality in both high-resolution HD and standard SD card. Exclusively selected additives such as an Ethernet port, USB port with recording capability and support for MP3, OGG, JPEG, MPEG changing receiver in the center of home entertainment. Despite the seemingly small differences in relation to more expensive models on the market, Ariva 200 is more versatile, and the current consumption in standby power exceeding 1W makes the receiver that will satisfy even the most demanding users. In addition, card reader and slot for CAM hidden under the flap on the front panel allow any pay to watch television in High Definition. Ariva 200 is by far the best source of HD digital satellite television.
    Specification:
    1. Receives high resolution (High Definition)
    2. Scaling PAL signal to 720p or 1080i
    3. Supports 32 programmable timers
    4. A separate list of favorite channels, TV and Radio
    5. Quick search channels (Quickfind)
    6. Supports teletext and subtitles on screen
    7. DiSEqC 1.0, 1.1 and DiSEqC 1.2, USALS
    8. Support for MPEG-2, MPEG-4, MPEG-4 AVC/H.264
    9. Compatible with DVB-S and DVB-S2
    10. Universal remote control unit RCU-640
    11. Card reader for pay TV
    12. CI slot
    Outputs:
    1. HDMI with HDCP
    2. LAN, USB 2.0, RS-232
    3. Component (Y, Pb, Pr)
    4. CVBS - RCA (Cinch) Video
    5. 2x RCA (RCA) analog audio
    6. Optical digital audio output
    7. Coaxial digital audio output S / PDIF
    Remote Control:
    Ariva 200 is supplied with an advanced 4-functional pilot symbol RCU-640. The pilot can operate four devices: satellite receivers brands Ferguson, programmed by the user any TV, receivers and DVD brands Ferguson brands Ferguson (table supported codes / brand TV is available on the last pages of instructions).
    Processor:
    Ariva 200 is built on the basis of advanced main unit (CPU) known producer ALi. A powerful M3602 cooperating with DDR memory provides the highest available quality of digital audio and video in High Definition.
    Dijital uydu alıcıları Şirket Ferguson m.in üretici, Eylül ayında yeni bir HD alıcıya başlatmayı planlıyor Ariva Ferguson 200 adını işaretlenmiş Yeni alıcı estetik tasarım ve uygun fiyat olmalıdır.
    Ariva 200 hem yüksek çözünürlüklü HD ve standart SD kart mükemmel bir görüntü kalitesi. Kapasitesi ve MP3, OGG, JPEG, MPEG ev eğlence merkezi değişen alıcı çekmek için kayıt ile bir Ethernet portu, USB portu gibi Exclusively seçilen katkılar. Piyasada daha pahalı modeller ile ilgili olarak görünen küçük farklılıklara rağmen, Ariva 200 daha fazla ve çok yönlü bir koleksiyon prAdu bekleme güç 1W aşan bile en zorlu kullanıcıları tatmin edecek alıcı hale getirir. Buna ek olarak, kart okuyucu ve CAM ön paneldeki kapağın altında gizli yuvası herhangi bir ödeme High Definition televizyon izlemek için izin verir. Ariva 200 HD dijital uydu televizyon çok iyi kaynak
    Alıcı Özellikler:
    Pick *-Yüksek Çözünürlüklü kanal (High Definition)
    * Ölçekleme PAL sinyali 720p veya 1080i için
    Supports 32 programlanabilir sayaçlarını
    * Favori kanallar, TV ve Radio ayrı bir liste
    * Hızlı kanal arama (Hızlı Bul)
    * Desteği Teletext ve ekranda alt
    * Support DiSEqC 1.0, 1.1 ve DiSEqC 1.2, USALS
    MPEG Support-2, MPEG-4, MPEG-4 AVC/H.264
    * Uyumlu DVB-S ve DVB-S2
    * Evrensel uzaktan kumanda RCU-640
    * Ödeme için kart okuyucu TV
    * CI yuvası
    Çıkışlar:
    * HDMI, HDCP ile
    * LAN, USB 2.0, RS-232
    * Component (Y, Pb, Pr)
    * CVBS - RCA (Cinch) Video
    * 2x RCA (RCA) analog ses
    * Optik dijital ses çıkışı
    * Koaksiyel dijital ses çıkışı S / PDIF
    Ariva 200 gelişmiş 4-fonksiyonel pilot sembol RCU-640 ile birlikte verilir. Pilot talimatların son sayfalarında mevcuttur) dört aygıt: uydu alıcıları markalar Ferguson, herhangi bir TV, alıcıları ve DVD markalar Ferguson marka Ferguson (tablo kodları desteklenen kullanıcı tarafından programlanan / marka TV çalıştırabilirsiniz.
    Ariva 200 gelişmiş ana birimi (CPU) üreticisi ALi bilinen temelinde inşa edilmiştir. Güçlü M3602 DDR bellek ile işbirliği dijital ses ve video in High Definition mevcut en yüksek kalite sağlar.
