Fet Transistör test devresi
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 18 Mart 2012 başlatılmıştır.
    Fet Transistör test devresi (fet tiransistörleri test etmekte kullanabileceğiniz çok basit bir elektronik devredir)
    Testing a MosFet
    This testing procedure is for use with a digital multimeter in the diode test-range with a minimum of 3.3 volt over d.u.t. (diode-under-test)
    Connect the 'Source' of the MosFet to the meter's negative (-) lead.
    1) Hold the MosFet by the case or the tab but don't touch the metal parts of the test probes with any of the other MosFet's terminals until needed.
    2) First, touch the meter positive lead onto the MosFet's 'Gate'.
    3) Now move the positive probe to the 'Drain'. You should get a 'low' reading. The MosFet's internal capacitance on the gate has now been charged up by the meter and the device is 'turned-on'.
    4) With the meter positive still connected to the drain, touch a finger between source and gate (and drain if you like, it does not matter at this stage). The gate will be discharged through your finger and the meter reading should go high, indicating a non-conductive device.
    Such a simple test is not 100% -- but is useful and usually adequate.
    When MOSFETS fail they often go short-circuit drain-to-gate. This can put the drain voltage back onto the gate where of course it feeds (via the gate resistors) into the drive circuitry, possibly blowing that section. It will also get to any other paralleled MosFet gates, blowing them also.
    So, if the MosFets are deceased, check the drivers as well! This fact is probably the best reason for adding a source-gate zener diode; zeners fail short circuit and a properly connected zener can limit the damage in a failure! You can also add subminiature gate resistors -- which tend to fail open-circuit (like a fuse) under this overload, disconnecting the dud MosFet's gate.
Benzer Konular - Fet Transistör test
  3. uydudoktoru
