JAF repair solution
Konusu 'Pic Uygulama Ve Devreleri' forumundadır ve guclusat tarafından 6 Ekim 2012 başlatılmıştır.
    New Solution Repair box JAF without resisters 330 and without remove chip LVC244A
    Step 1: You have to find a stem LPT port cable as shown:
    Just like on the Jack LPT port to attach to the back of the computer.
    And on what it has stated that Jack LPT number from 1 to 25 feet (see wealth in'll see). And we only care about 4 feet.
    No. 6 feet ..........( called SCK)
    No. 7 foot ..............( called Mosi)
    No. 9 feet ..............( called reset)
    foot No. 10 ............( called miso)
    As shown below:
    Step 2: Open Box JAF and welding as Figure 1 below.
    Step 3: View behind JAF BOX. using a scalpel and cut as shown in Figure 3 below.
    Step 4: Connect the USB for the JAF Box to use GND and 5V Voltage
    Step 5: Download: soft + Firmware of JAF box
    Step 6: Install PonyProg_V207c
    Step 7: After installation is complete, we set up as shown below.
    The steps to load and select the file you just need to conform to the video is 100% OK. The most important problem is the connection with JAF BOX LPT port only.
    [video=youtube;uF8HrXt3i1Y]http://www.youtube.com/watch?v=uF8HrXt3i1Y[/video]
    Thanks mr zopo
    THE IMAGE ABOVE is 100% TESTED to ME but NOT "DEAD JAF BOX " coz I DON'T HAVE DEAD JAF BOX
    but converting
    = ATmega8-16AU (32 pins from OTHER BOX WORKING) to USB programmer for Atmel AVR controllers
    = ATmega8L-8PI (28 pins from OTHER BOX WORKING) to USB programmer for Atmel AVR controllers
    NOW MAKING PCB for this 2 TYPE of Microcontroller to be ABLE TO USE USB NOT PRINTER PORT.
    for more info about USBasp CHECK IT
    HERE.
    IF I HAVE TIME, I'LL TRY TO CONVERT ATmega128 from OTHER BOX to put it in my OTHER JAF BOX.
Benzer Konular - JAF repair solution
