Kendi Bilgisayarınızın Özellikleri Nelerdir
Konusu 'Genel PC Konuları' forumundadır ve guclusat tarafından 30 Mart 2010 başlatılmıştır.
    Ben cpuz ile küçük bir döküman hazırladım.İşte resimler
    resimleri karışık verdim aşağıdaki resimi ayrı veriyorum Overclock yaptıktan sonraki performasn artışını gösteriyor
  2. HUNTERKERİM
    HUNTERKERİM Üye Kayıtlı Üye
    18 Şubat 2010
    benim pc i
    Son düzenleyen: Moderatör: 30 Mart 2010
  3. HUNTERKERİM
    18 Şubat 2010
    cpu z txt dokuman
    3..JPG -------------------------
    CPU-Z version 1.51
    Processors Map
    Number of processors 1
    Number of threads 4
    Processor 0
    -- Core 0
    -- Thread 0
    -- Core 1
    -- Thread 0
    -- Core 2
    -- Thread 0
    -- Core 3
    -- Thread 0
    Processors Information
    Processor 1 (ID = 0)
    Number of cores 4 (max 4)
    Number of threads 4 (max 4)
    Name AMD Phenom II X4 945
    Codename Deneb
    Specification AMD Phenom(tm) II X4 945 Processor
    Package Socket AM2+ (940)
    CPUID F.4.2
    Extended CPUID 10.4
    Brand ID 13
    Core Stepping RB-C2
    Technology 45 nm
    Core Speed 3010.2 MHz (15.0 x 200.7 MHz)
    HT Link speed 2006.8 MHz
    Stock frequency 3000 MHz
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
    L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
    L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
    L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
    L3 cache 6 MBytes, 48-way set associative, 64-byte line size
    FID/VID Control yes
    FID range 5.0x - 15.0x
    max VID 1.325 V
    Features XD, VT
    Package Type 0x1
    Model 45
    String 1 0x3
    String 2 0x6
    Page 0x0
    Attached device PCI device at bus 0, device 24, function 0
    Attached device PCI device at bus 0, device 24, function 1
    Attached device PCI device at bus 0, device 24, function 2
    Attached device PCI device at bus 0, device 24, function 3
    Attached device PCI device at bus 0, device 24, function 4
    Thread dumps
    CPU Thread 0
    APIC ID 0
    Topology Processor ID 0, Core ID 0, Thread ID 0
    Type 02004009h
    Max CPUID level 00000005h
    Max CPUID ext. level 8000001Bh
    Cache descriptor Level 1 I 64 KB 1 thread(s)
    Cache descriptor Level 1 D 64 KB 1 thread(s)
    Cache descriptor Level 2 U 512 KB 1 thread(s)
    Cache descriptor Level 3 U 6 MB 4 thread(s)
    MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
    MSR 0xC0010061 edx = 0x00000000 eax = 0x00000030
    MSR 0xC0010062 edx = 0x00000000 eax = 0x00000000
    MSR 0xC0010063 edx = 0x00000000 eax = 0x00000000
    MSR 0xC0010064 edx = 0x800001B5 eax = 0x3800240E
    MSR 0xC0010065 edx = 0x80000191 eax = 0x38003407
    MSR 0xC0010066 edx = 0x80000184 eax = 0x38004402
    MSR 0xC0010067 edx = 0x8000014D eax = 0x38005C40
    MSR 0xC0010068 edx = 0x00000000 eax = 0x40000000
    MSR 0xC0010071 edx = 0x30BC0093 eax = 0x3800240E
    MSR 0xC0010015 edx = 0x00000000 eax = 0x01000010
    MSR 0xC001001F edx = 0x00584000 eax = 0x00000008
    MSR 0xC0010058 edx = 0x00000000 eax = 0xE0000021
    MSR 0xC0010070 edx = 0x00000000 eax = 0x3800240E
    CPU Thread 1
    APIC ID 1
    Topology Processor ID 0, Core ID 1, Thread ID 0
    Type 02004009h
    CPU Thread 2
    APIC ID 2
    Topology Processor ID 0, Core ID 2, Thread ID 0
    Type 02004009h
    CPU Thread 3
    APIC ID 3
    Topology Processor ID 0, Core ID 3, Thread ID 0
    Type 02004009h
    Chipset
    Northbridge AMD 780G rev. 00
    Southbridge ATI SB700 rev. 00
    Graphic Interface PCI-Express
    PCI-E Link Width x16
    PCI-E Max Link Width x16
    Memory Type DDR2
    Memory Size 2048 MBytes
    Channels Single
    Memory Frequency 535.1 MHz (3:8)
    CAS# 5.0
    RAS# to CAS# 7
    RAS# Precharge 7
    Cycle Time (tRAS) 24
    Bank Cycle Time (tRC) 31
    Command Rate 2T
    NB Frequency 2006.8 MHz
    Memory SPD
    DIMM #1
    General
    Memory type DDR2
    Module format Regular UDIMM
    Manufacturer (ID) Kingston (7F98000000000000)
    Size 1024 MBytes
    Max bandwidth PC2-6400 (400 MHz)
    Part number 99U5315-039.A00LF
    Serial number A6CC5F3E
    Manufacturing date Week 23/Year 09
    Attributes
    Number of banks 1
    Data width 64 bits
    Correction None
    Nominal Voltage 1.80 Volts
    EPP no
    XMP no
    Timings table
    Frequency (MHz) 200 266 400
    CAS# 3.0 4.0 5.0
    RAS# to CAS# delay 3 4 5
    RAS# Precharge 3 4 5
    TRAS 9 12 18
    TRC 12 16 23
    DIMM #2
    General
    Memory type DDR2
    Size 1024 MBytes
    Serial number BCCCB077
    Attributes
    Number of banks 1
    Data width 64 bits
    Correction None
    EPP no
    XMP no
    Timings table
    CAS# 3.0 4.0 5.0
    TRAS 9 12 18
    TRC 12 16 23
    D
    Hardware monitor
    ITE IT87 hardware monitor
    Voltage sensor 1 2.14 Volts [0x86] (VIN1)
    Voltage sensor 2 1.14 Volts [0x47] (+3.3V)
    Voltage sensor 3 5.16 Volts [0xC0] (+5V)
    Voltage sensor 8 3.46 Volts [0xD8] (VBAT)
    Temperature sensor 0 38°C (100°F) [0x26] (TMPIN0)
    Temperature sensor 1 32°C (89°F) [0x20] (TMPIN1)
    Fan sensor 0 3054 RPM [0xDD] (FANIN0)
    Dump hardware monitor
    L
    Hardware monitor
    AMD Phenom II X4 945 hardware monitor
    Temperature sensor 0 35°C (95°F) [0x11B] (Core #0)
    Temperature sensor 1 35°C (95°F) [0x11A] (Core #1)
    Temperature sensor 2 35°C (95°F) [0x11A] (Core #2)
    Temperature sensor 3 35°C (95°F) [0x11A] (Core #3)
    Hardware monitor
    ATI Radeon HD 5700 Series hardware monitor
    Voltage sensor 0 0.95 Volts [0x0] (GPU Core)
    Temperature sensor 0 41°C (105°F) [0x29] (GPU Core)
    PCI Device List
    Host Bridge
    bus 0 (0x00), device 0 (0x00), function 0 (0x00)
    Common header
    Vendor ID 0x1022
    Model ID 0x9600
    Revision ID 0x00
    PI 0x00
    SubClass 0x00
    BaseClass 0x06
    Cache Line 0x00
    Latency 0x00
    Header 0x00
    PCI header
    Subvendor ID 0x1043
    Subsystem ID 0x82F1
    Int. Line 0x00
    Int. Pin 0x00
    Capabilities
    HyperTransport Capability
    Offset C4h
    Revision 3.00
    Interface type Slave/Primary
    Link 0 width (in/out) 16 bits/16 bits
    Link 0 frequency 2000MHz
    Link 1 width (in/out) 8 bits/8 bits
    Link 1 frequency 200MHz
    Offset 54h
    Interface type Clumping
    Offset 40h
    Interface type Retry Mode
    Offset 9Ch
    Interface type Gen3
    Offset F8h
    Interface type Power Management
    D
    PCI to PCI Bridge
    bus 0 (0x00), device 2 (0x02), function 0 (0x00)
    Common header
    Vendor ID 0x1022
    Model ID 0x9603
    Revision ID 0x00
    PI 0x00
    SubClass 0x04
    BaseClass 0x06
    Cache Line 0x10
    Latency 0x00
    Header 0x01
    PCI header
    Primary bus 0x00
    Secondary bus 0x01
    Int. Line 0x12
    Int. Pin 0x01
    Capabilities
    Power Management Capability
    Offset 50h
    Version 1.2
    PCI Express Capability
    Offset 58h
    Device type Root Port of PCI-E Root Complex
    Port 0
    Version 2.0
    Physical slot #0
    Presence detect yes
    Link width 16x (max 16x)
    Message Signalled Interrupts Capability
    Offset A0h
    Subsystem Vendor Capability
    Offset B0h
    Subsystem ID 0x82F1
    Sub. Vendor ID 0x1043
    Offset B8h
    Interface type MSI Mapping
    PCI to PCI Bridge
    bus 0 (0x00), device 6 (0x06), function 0 (0x00)
    Common header
    Vendor ID 0x1022
    Model ID 0x9606
    Revision ID 0x00
    PI 0x00
    SubClass 0x04
    BaseClass 0x06
    Cache Line 0x10
    Latency 0x00
    Header 0x01
    PCI header
    Primary bus 0x00
    Secondary bus 0x02
    Int. Line 0x12
    Int. Pin 0x01
    Capabilities
    Offset 50h
    Version 1.2
    Offset 58h
    Port 3
    Version 2.0
    Physical slot #0
    Presence detect yes
    Link width 1x (max 1x)
    Offset A0h
    Offset B0h
    Subsystem ID 0x82F1
    Offset B8h
    IDE Controller
    bus 0 (0x00), device 17 (0x11), function 0 (0x00)
    Common header
    Vendor ID 0x1002
    Model ID 0x4390
    Revision ID 0x00
    PI 0x8F
    SubClass 0x01
    BaseClass 0x01
    Cache Line 0x10
    Latency 0x40
    Header 0x00
    PCI header
    Address 0 (port) 0x0000B000
    Address 1 (port) 0x0000A000
    Address 2 (port) 0x00009000
    Address 3 (port) 0x00008000
    Address 4 (port) 0x00007000
    Address 5 (memory) 0xFBCFFC00
    Subvendor ID 0x1043
    Subsystem ID 0x82EF
    Int. Line 0x16
    Int. Pin 0x01
    Capabilities
    Offset 60h
    Version 1.1
    PCI Capability class 0x12
    Offset 70h
    USB Controller (OHCI)
    bus 0 (0x00), device 18 (0x12), function 0 (0x00)
    Common header
    Vendor ID 0x1002
    Model ID 0x4397
    Revision ID 0x00
    PI 0x10
    SubClass 0x03
    BaseClass 0x0C
    Cache Line 0x10
    Latency 0x40
    Header 0x80
    PCI header
    Address 0 (memory) 0xFBCFD000
    Subvendor ID 0x1043
    Subsystem ID 0x82EF
    Int. Line 0x10
    Int. Pin 0x01
    DMI BIOS
    vendor American Megatrends Inc.
    version 1501
    date 09/14/2009
    DMI System Information
    manufacturer System manufacturer
    product System Product Name
    version System Version
    serial System Serial Number
    UUID A0F4FC1D-8432DE11-A2E50024-8CA7E233
    DMI Baseboard
    vendor ASUSTeK Computer INC.
    model M4A78 PRO
    revision Rev 1.xx
    serial MS1C94BJ5K01866
    DMI System Enclosure
    manufacturer Chassis Manufacture
    chassis type Desktop
    chassis serial Chassis Serial Number
    DMI Processor
    manufacturer AMD
    model AMD Phenom(tm) II X4 945 Processor
    clock speed 3000.0 MHz
    FSB speed 200.0 MHz
    multiplier 15.0x
    DMI Port Connector
    designation PS/2 KeyBoard (internal)
    designation Keyboard (external)
    port type Keyboard Port
    connector PS/2
    DMI Port Connector
    designation PS/2 Mouse (internal)
    designation PS/2 Mouse (external)
    port type Mouse Port
    connector PS/2
    DMI Port Connector
    designation USB12 (internal)
    designation USB12 (external)
    port type USB
    connector Access Bus (USB)
    DMI Port Connector
    designation USB34 (internal)
    designation USB34 (external)
    port type USB
    DMI Port Connector
    designation COM 1 (internal)
    designation COM 1 (external)
    port type Serial Port 16550A
    connector DB-9 male
    DMI Port Connector
    designation LAN (internal)
    designation LAN (external)
    port type Network Port
    connector RJ-45
    DMI Port Connector
    designation Audio_Line_In (internal)
    designation Audio_Line_In (external)
    port type Audio Port
    connector Mini Jack (headphones)
    DMI Port Connector
    designation Audio_Line_Out (internal)
    designation Audio_Line_Out (external)
    DMI Port Connector
    designation Audio_Mic_In (internal)
    designation Audio_Mic_In (external)
    DMI Port Connector
    designation Audio_Center/Sub (internal)
    designation Audio_Center/Sub (external)
    DMI Port Connector
    designation Audio_Rear (internal)
    designation Audio_Rear (external)
    DMI Port Connector
    designation Audio_Side (internal)
    designation Audio_Side (external)
    DMI Port Connector
    designation HDMI (internal)
    designation HDMI port (external)
    DMI Port Connector
    designation DVI (internal)
    designation DVI port (external)
    DMI Port Connector
    designation SPDIFO (internal)
    designation SPDIFO (external)
    DMI Port Connector
    designation PRI IDE (internal)
    connector On Board IDE
    DMI Port Connector
    designation SATA1 (internal)
    DMI Port Connector
    designation SATA2 (internal)
    DMI Port Connector
    designation SATA3 (internal)
    DMI Port Connector
    designation SATA4 (internal)
    DMI Port Connector
    designation SATA5 (internal)
    DMI Port Connector
    designation SATA6 (internal)
    DMI Port Connector
    designation CPU FAN (internal)
    DMI Port Connector
    designation CHA FAN (internal)
    DMI Port Connector
    designation PWR FAN (internal)
    DMI Port Connector
    designation USB56 (internal)
    port type USB
    DMI Port Connector
    designation USB78 (internal)
    port type USB
    DMI Port Connector
    designation USB910 (internal)
    port type USB
    DMI Port Connector
    designation USB1112 (internal)
    port type USB
    DMI Port Connector
    designation FLOPPY (internal)
    connector On Board Floppy
    DMI Port Connector
    designation SPDIF OUT (internal)
    DMI Port Connector
    designation AAFP (internal)
    DMI Port Connector
    designation CD (internal)
    connector On Board Sound Input From CD-ROM
    DMI Extension Slot
    designation PCIEX16
    type A5
    width 32 bits
    populated yes
    DMI Extension Slot
    designation PCIEX1_1
    type A5
    width 32 bits
    populated no
    DMI Extension Slot
    designation PCIEX1_2
    type A5
    width 32 bits
    populated no
    DMI Extension Slot
    designation PCI_1
    type PCI
    width 32 bits
    populated no
    DMI Extension Slot
    designation PCI_2
    type PCI
    width 32 bits
    populated no
    DMI Extension Slot
    designation PCI_3
    type PCI
    width 32 bits
    populated no
    DMI OEM Strings
    string[0] 00248CA7E233
    string[1] To Be Filled By O.E.M.
    string[2] To Be Filled By O.E.M.
    string[3] To Be Filled By O.E.M.
    DMI Physical Memory Array
    location Motherboard
    usage System Memory
    correction None
    max capacity 16384 MBytes
    max# of devices 4
    DMI Memory Device
    designation DIMM_A1
    format DIMM
    type unknown
    total width 64 bits
    data width 72 bits
    size 1024 MBytes
    DMI Memory Device
    designation DIMM_B1
    format unknown
    type unknown
    data width 64 bits
    DMI Memory Device
    designation DIMM_A2
    format DIMM
    type unknown
    total width 64 bits
    data width 72 bits
    size 1024 MBytes
    DMI Memory Device
    designation DIMM_B2
    format unknown
    type unknown
    data width 64 bits
    Display API(s)
    ATI direct I/O API
    ATI OD5 display API
    Display Adapter(s)
    Device number 0
    Name ATI Radeon HD 5700 Series
    Vendor ID 0x1002 (0x1002)
    Model ID 0x68B8 (0x2543)
    Revision ID 0x0
    GPU core clock 157.0 MHz
    GPU memory clock 300.0 MHz
    GPU temperature 40 C
    Display I2C
    Software
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    DirectX Version 9.0c
    AMD PHENOM X4 945 3.0,SAMSUNG 320 GB+SAMSUNG 1TB HDD,SAPPHİRE ATİ HD 5770,KINGSTOM HYPERX 1066 MHZ 2GB RAM,LİFE VİEW DVB-S,CREATİVE 7.1 AUDIGY,ASUS AMD M4A78 PRO ANAKART HD 3450 VGA,RAİDMAX 630 WATT PSU,RAİDMAX SMİLDOON KASA,ASUS LİGHT SCRİBE DVD RW,PHILIPS DVD RW,SAMSUNG 22' SYNCMASTER 223 BW EKRAN,LOGİTECH 5.1 SES
    Son düzenleyen: Moderatör: 1 Nisan 2010
Benzer Konular - Kendi Bilgisayarınızın Özellikleri
