LED as light detector
Konusu 'Elektronik Devreler' forumundadır ve uydudoktoru tarafından 10 Temmuz 2011 başlatılmıştır.
    Did you know that the LED can be used as a light detector?
    In fact green LEDs are the best for this, but all LEDs will detect light and produce a voltage equal to the characteristic voltage-drop. The current they produce is very small, only the super and high bright one can produce a higher output due to the fact that their crystal is more efficient at converting light into electricity
Benzer Konular - LED light detector
  2. uydudoktoru
  5. uydudoktoru
