LED Transistor Tester 1
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 9 Aralık 2015 başlatılmıştır.
    Online
    [​IMG] [​IMG]
    If the transistor under test (TUT) is unknown, and SW1is in the wrong position, three LEDS wil glow when SW2 is in the collector or in the emitter position, while only one LED wil glow when SW2 is in the base position. So if three of the LEDS glow twice like in the circuit above, it means you have the wrong polarity, the transistor is not a PNP but a NPN type.
    [​IMG] [​IMG]
    With the same TUT, switch SW1 to the NPN position. Now, only one LED will glow when SW2 is in the collector or in the emitter position, while three LEDS wil glow when SW2 is in the base position, no matter if the base is connected to D1/D2, D3/D4 or D5/D6.
    With this circuit, you can define whether your transistor is a PNP or NPN type and which of the leads is the base.
    Once this is done, LED Transistor Tester 2 can define the collector lead and the emitter lead.
    Parts List
    Unless otherwise stated, resistor wattage = 0.25W.
    • R1, R2, R3 = 1.8KΩ - 2.2KΩ
    • D1, D2, D3, D4, D5, D6 = LED
    • SW1 = DPDT (double pole, double throw)
    • SW2 = SPTT (single pole, treble throw)
Benzer Konular - LED Transistor Tester
  4. uydudoktoru
