Mac OS X SnowLeo 10.6 for Intel/AMD (x32/x64)
Konusu 'Program Arsivi' forumundadır ve haingoc tarafından 10 Haziran 2011 başlatılmıştır.
  1. haingoc
    Online
    haingoc Guest
    Mac OS X SnowLeo 10.6 for Intel/AMD (x32/x64) | 2.9 GB
    Installation DVD Mac OS X Snow Leopard for computers with Intel/AMD. The assembly supports a large amount of iron as close to the original, contains many drivers and fixes, not cluttered over musorom.Edinstvenny Bars which was no problem on my AMD:)
    Additional Information:
    Osnnovnye BIOS settings: SATA Mode select AHCI (who do not, so do not let it be IDE), ACPI APIC set Enabled, ACPI - Enabled, SATA Native - Disable / Enable.
    Problems before / after the installation: When you first boot (after install) loaded with key-v-f. When panic on multicore processors, loaded with keys cpus = 1 or cpus = 1 bustratio = 20. If the problem when booting from the DVD, try to boot from mach_970.Drova the video does not choose as spelled autodetection, if not become, it then self-install.
    In com.apple.boot.plist registered by default 32-bit mode. Holders of Intel processors (which work with the original kernel), open the folder / Extra, there com.apple.boot.plist open and clean arch = 386 (must stay
    Kernel Flags
    The first run always with the keys:-V-F!!! Russik attached.
    Likewise, anyone with an AMD processor need to patch some files for it after the installation is located in the Application Program Marvin `s AMD Utility, select the left Patch All Binaries, but with the right to select the System folder and click Run.
    Once the program is to patch the files it hover (the slider should go to the end), just overload the computer and everything, do not worry, everything went smoothly.
    I personally upgraded from office site to 10.6.3, but after a reboot did not go, do the following: put the disc again and start to reinstall all the prog, wood (all of which reads upgrade, except for the base system and remove or put (I do not remember exactly Read the hint) check at the bottom where it says finish) and voila, working SNOW LEO 10.6.3!
    Year: 2010
    Assembling: Director AK
    Language: English
    System requirements:
    - CPU Intel/AMD with support for SSE2 SSE3
    - 512 MB RAM
    - 128 MB Graphics Card
    - 7-8 GB of free disk space
    http://www.filesonic.com/file/1170950174/Snow...6.DVD.part1.rar
    http://www.filesonic.com/file/1170960964/Snow...6.DVD.part2.rar
    http://www.filesonic.com/file/1170957034/Snow...6.DVD.part3.rar
    http://www.filesonic.com/file/1170964944/Snow...6.DVD.part4.rar
    http://www.filesonic.com/file/1170983371/Snow...6.DVD.part5.rar
    http://www.filesonic.com/file/1170978214/Snow...6.DVD.part6.rar
    http://www.filesonic.com/file/1170969391/Snow...6.DVD.part7.rar
Benzer Konular - Mac SnowLeo Intel
  2. yanfan001
  3. yanfan001
  4. yanfan001
  5. yanfan001
