MultiBoot DVD-X5 2011 Eng (Jun 2011)
Konusu 'Program Arsivi' forumundadır ve omega tarafından 24 Haziran 2011 başlatılmıştır.
  1. omega
    Online
    omega Guest
    MultiBoot DVD-X5 2011 Eng (Jun 2011) | 4GB
    Multiboot DVD-ROM for backup and restoration of the hard disk, the treatment of viruses, reset forgotten passwords, etc.
    Changes compared with version X4 (14.0)
    Added:
    - Acronis True Image Home 2011 Plus Pack Full & Safe 14.0.6696 EN
    - Paragon Hard Disk Manager 2011 Suite Recovery CD WinPE Based
    - AVG Rescue CD 100.110314 (Virus database 28.03.2011)
    - HDD Regenerator 2011
    Changed:
    - Hiren’s Boot CD 13.1 (in version X4 was: Hiren’s Boot C4D 13.0)
    - LiveCD Windows’7 v5.5c by xalex (January 2011) (in version X4 was: LiveCD Windows 7 v5.2 by xalex 05.12.2010)
    - Active @ Boot Disk v5.1.3 Windows PE & DOS (in version X4 was: Active @ Boot Disk v5.1.2)
    - Avast! BartCD 2.0 Build 4.7.1051.0 EN Virus database 31.03.2011 (in version X4 were: Avast! BartCD 2.0 Build 4.7.1051.0 EN Virus database 08.01.2011)
    Deleted:
    - Acronis True Image Home 2011 Plus Pack Full & Safe 14.0.6597 RU
    - Paragon Hard Disk Manager 2010 Build 9369 Professional
    - Kaspersky Rescue Disk 10.0.23.29 MultiLang
    - HDD Regenerator v1.71
    - HDD Regenerator v1.61
    - HDD Regenerator v1.51
    MultiBoot DVD X5 contains:
    Alkid LiveCD Full with drivers and without drivers 28.08.2010 – at full strength. Updated anti-virus DrWeb until 03/31/2011.
    Description: Alkid LiveCD – Universal boot disk to work and restore the system. Contains a set of antivirus, tools for working with disks and images, backup and lifting systems, restore lost information and passwords, create new administrative ***s, return to the point of rollback, your system info, etc. Works with SATA disks and RAID arrays, mounts a volume Linux, provides a rich set of networking and SATA / SCSI / RAID drivers. In the Full version has sound and video drivers.
    Hiren’s Boot CD + WindowsPE LiveCD:
    Hiren’s Boot CD 13.1 – in full (Keyboard otpatchena for the Russian language).
    Description: Hiren’s BootCD – stunningly competently and professionally assembled, the most popular boot “all-in-one drive, literally everyone, including administrators and administrators for the repair work on the computer. With its small size, contains a wealth of best world-class programs to do almost everything to “eject” and return your computer to life, identifying and testing different devices and your computer meets the highest requirements. Also includes anti-virus software with the ability to update databases, anti-spyware program to the disk: formatting, partition, repair, testing, etc., cloning systems, power data recovery after the collapse of Windows, the tools to identify hardware, work with the BIOS, and much more .
    In the boot menu Hiren’s Boot CD item added: Go to WindowsPE & Linux LiveCD Menu -> -> ->
    From this menu item, switch to the menu “WindowsPE & Linux LiveCD”, from which you are downloading the following baziruschihsya on WindowsPE and Linux LiveCD:
    Software Acronis:
    - Acronis Disk Director 11.0.12077 Advanced
    - Acronis Disk Director Home 11.0.2121
    - Acronis Backup & Recovery Server v10.0.12703 with Universal Restore
    - Acronis Backup & Recovery Workstation v10.0.12497 with Universal Restore
    Software Paragon:
    - Paragon Partition Manager 10.0.7893 Server Edition
    Windows LiveCD:
    Description of the programs in the menu WindowsPE & Linux LiveCD:
    Software Acronis:
    Acronis Disk Director 11.0.12077 Advanced – a powerful and convenient tool to manage disks and volumes on local and remote machines. Exhaustive set of performed operations allows you to organize your hard drive and adjust the volume for optimal performance while ensuring data security. Acronis Disk Director 11 Advanced Workstation provides powerful tools for managing hard disks and partitions, which will ensure efficient operation of your workstation. Acronis has long supported operating system, Microsoft, and this version is a fully supported platform for Windows 7 and Windows Vista and Windows XP. You can perform dynamic partition, merge, resize, copy and move partitions from within Windows, by reducing unproductive downtime. Now you can quickly perform tasks by modifying the contents of your hard drive, including the restoration of important areas of data on your hard drive, determination and / or retrieve information lost due to different software or hardware failures or virus attacks.
    From the main boot menu is launched the following programs:
    Micro-Scope Diagnostic Suite v14 – Diagnostic software package intended for a comprehensive diagnosis of the components of computers, from the disks, controllers, processors to motherboards and memory modules.
    HDD Regenerator – a program to restore the hard drive. The program eliminates physical damages (bad sectors) with the disk surface. She does not hide bad sectors, it really restores them! Almost 60% of damaged hard drives have incorrectly magnetized surface. Program developers have found a special algorithm for sequences of signals of low and high level. These signals are generated by the program and change the damaged area. Even low-level format can not cope with this task! HDD Regenerator regenerates bad sectors reversal. Almost 60pc of hard drive beyond repair program. As a result, corrupted and unreadable information is restored without any impact on existing data.
    Checksums:
    File: MultiBoot DVD X5 afin 2011-04-01.iso
    Size: 3,98 GB (4,281,391,104 bytes)
    CRC32: 0A5CD2B7
    MD5: 7E5B9D34C8F4FA36D2E43876EA0AF947
    SHA-1: 82B17649C03020C469CE2DE09D56300A059B592D
    System requirements:
    PC with RAM> 512 MB (1 GB recommended or higher) and DVD-ROM
    Attention!
    The disc is not installed or zapuskantsya of the operating system! The exception is Startup Tools from the Hiren’s Boot CD
    Filesonic.com Fileserve.com Rapidshare.com Hotfile.com
    I will check, If link die, I will reupload at here
    http://tinypaste.com/19709
    Download Filesonic
    http://www.filesonic.com/file/1241316454/MDVDx5x.part01.rar
    http://www.filesonic.com/file/1241316464/MDVDx5x.part02.rar
    http://www.filesonic.com/file/1241322044/MDVDx5x.part03.rar
    http://www.filesonic.com/file/1241327884/MDVDx5x.part04.rar
    http://www.filesonic.com/file/1241334414/MDVDx5x.part05.rar
    http://www.filesonic.com/file/1241360764/MDVDx5x.part06.rar
    http://www.filesonic.com/file/1241367824/MDVDx5x.part07.rar
    http://www.filesonic.com/file/1241367864/MDVDx5x.part08.rar
    http://www.filesonic.com/file/1241334394/MDVDx5x.part09.rar
Benzer Konular - MultiBoot DVD 2011
  3. zac34
  4. zac34
  5. zac34
