Musical Doorbell with Over Door Light
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 28 Mart 2014 başlatılmıştır.
    Inspired by a code snippet found on internet, recently I have designed one simple but versatile Musical Doorbell with Over Door Light circuit using the 8-Pin microcontroller PIC12F675. This is a fascinating door bell with 4 different melodies, plus a switch output to control an electric lamp (as an overdoor light) in the external world. The main circuit is ultra compact and can be powered from any 6V battery supply.
    Features:
    • Works on 6V battery
    • 4-tune melody output
    • Very small circuit board
    • Automatic overdoor light switching
    • Perfect galvanic isolation
    • Moderate current consumption
    With a little skill and patience, you can easily enclose the whole circuit in a small plastic box with the bell-push switch (S1) fitted in front of it. Link to the overdoor light (L1) and piezo-speaker (PZ1) can be extended from the enclosure using suitable length of wires/cables.
    Schematic of the musical doorbell circuit
    Parts List:
    • IC1: PIC12F675
    • T1: BC547
    • TR1: BT136
    • PC1: MOC3021
    • D1: 1N4007
    • LED1: Red (low current type)
    • PZ1: Piezo-Speaker (not piezo-buzzer)
    • S1: Push ON switch
    • L1: AC230V incandescent lamp
    • R1 to R4: 2K ¼ w
    • R5: 220R ¼ w
    • R6:180R ½ w
    • R7: 680R ½ w
    • C1: 100uF/16V
    • C2: 100nF
    • C3: 0.1uF/275VAC
    Warning!
    HIGH VOLTAGE, LETHAL POTENTIALS ARE PRESENT IN THIS CIRCUIT
    Son düzenleme: 8 Nisan 2017
Benzer Konular - Musical Doorbell Door
  2. uydudoktoru
  3. uydudoktoru
