Ornamental LED
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 4 Ekim 2010 başlatılmıştır.
    The circuit is a simple Astable multivibrator using two NPN transistors T1 and T2.The circuit works on the principle of charging and discharging of capacitors C1 and C2. Current from the positive of battery flows through first set of LEDs D1-D5 to the collector of T1 through resistor R1. Resistor R1 limits current through the LEDs to protect them. The current through R1 and LEDs charge capacitor C1. It then discharges through the base of T2 and resistor R4. This gives base current to T2 and it conducts. As a result second set of LEDs D6-D10 lights.As the Capacitor C1 discharges completely, T2 turns off. LEDs D6-D10 also turns off. The same thing happens in the other side also. This gives alternate flashing of LEDs.Thus the flashing effect is produced through the switching of T1 and T2 by the charge from capacitors.Flashing rate can be changed by changing the value of R3,R4 or C1,C2. If 500K preset is used in the place of R3/R4, flashing rate can be varied.
    Ornamental LED Circuit
    Son düzenleme: 20 Ekim 2011
Benzer Konular - Ornamental LED
