PerfectDisk 12 AIO (Original)
  • Konbuyu başlatan haingoc
  • Başlangıç tarihi
H
haingoc
Guest
PerfectDisk 12 AIO (Original) | 900MB
Maximize your hardware investments while improving productivity across your business. PerfectDisk 12 Professional provides smarter defrag and optimization for all your drives and saves energy costs by reducing the use of CPU and disk I/O resources. Designed for small business environments with non-networked PCs.
PerfectDisk 12 Professional for Networks
Maximize your hardware investments while improving productivity across your business. PerfectDisk 12 Professional for Networks provides smarter defrag and optimization for all your drives and saves energy costs by reducing the use of CPU and disk I/O resources.Scalable for SMBs and large enterprises that want to centrally manage an entire network.
PerfectDisk 12 Server
Optimize server performance to its full capability with PerfectDisk 12 Server defrag and optimization utility. Speed up processing times so your entire server environment is running as efficiently as possible. Scalable for SMBs and large enterprises that want to centrally manage an entire network.
PerfectDisk 12 ExchangeAutomate the compaction and internal content defragmentation of Microsoft Exchange data stores. Completely automate ESEUTIL so you can perform exchange maintenance with confidence. Scalable for SMBs and large enterprises that want to centrally manage an entire network.
Enterprise Management
PerfectDisk 12 Enterprise Console
The PerfectDisk 12 Enterprise Console allows you to centrally manage defragmentation across your entire network. Provides the most comprehensive alerting and notification system ensuring timely updates on drive health. PerfectDisk 12 Enterprise Console integrates with PerfectDisk 12 Professional for Networks, vSphere, Hyper-V, Server and Exchange editions.
Virtualization PerfectDisk 12 vSphere
Maximize the efficiency of the physical host?s resource utilization, optimize guests to eliminate I/O bottlenecks, eliminate resource contention. Zero-fill feature provides the ability to compress the virtual hard drive and reclaim space in thin provisioned environments.
PerfectDisk 12 Hyper-V
Total automation and flexibility combined with robust central management to provide complete defragmentation of your production Hyper-V environment. PerfectDisk Hyper-V utilizes patent-pending Virtual Aware defragmentation to improve Windows Server 2008 Hyper-V performance while eliminating resource contention, so your virtual environment runs better than ever.
PerfectDisk 12 VMware Workstation
Improve the performance in your VMware Workstation for Windows environment in accordance with VMware recommendations. Boost performance on both the physical host and virtual guests, while reducing resource consumption on both. Virtual Infrastructure Awareness Technology eliminates resource contention caused by simultaneous optimizations.
Key Features:
* Faster Performance for PCs and laptops
* Automatic background defrag and optimization
* OptiWrite? for fragmentation prevention
* S.M.A.R.T. monitoring of physical drives
* Advanced reporting and setting control features
* Designed for today's power user looking for optimum PC performance
* Windows 7 Defrag Center
PerfectDisk 12 Professional automates the optimization of PCs to boost user productivity by speeding up application launch times and boot times, and helping prolong system and hard drive life.
Fragmentation Prevention with OptiWrite?
PerfectDisk's new OptiWrite? technology prevents most fragmentation on your drive before it occurs, which prevents your system from slowing down. OptiWrite? detects when Windows is going to fragment files and intelligently redirects I/O to stop the fragmentation from occurring. System performance is maintained and the need to utilize CPU and Disk I/O resources to defragment files is greatly reduced. Because less defragmentation is needed, there is a direct benefit in the form of energy saved in both CPU usage and in the reading and writing to a disk. It saves users both in energy costs and in the time required to defragment a file system.
Intelligent Disk Optimization
For the limited fragmentation that can still occur, PerfectDisk's patented SMARTPlacement optimization strategy optimizes disk drives according to your unique usage patterns. SMARTPlacement results in the most consolidated free space available, the elimination of most fragmentation before it occurs, and a reduced rate of fragmentation.
SSD Optimizeis an optimization method for SSDs that focuses on free space consolidation without defragmentation of files. Solid State Drives are not affected by file fragmentation like traditional electromechanical disk drives. As such, it will leave files in a fragmented state while consolidating free space into large pieces.
Auto-Optimization for Complete Unattended Optimization
PerfectDisk?s exclusive StealthPatrol? tab is used to set automatic fragmentation prevention and optimize your system when it isn't busy. Auto-optimization affords you the flexibility to optimize your system when it is idle or when the Windows screensaver is active. Auto-optimization provides the flexibility to not run during certain periods of the day or when a user-defined application is running. No other defrag or optimization utility proves this level of flexibility.
Advanced Boot Time Defrag
An important factor in faster PC performance is a thorough boot time defrag. PerfectDisk's advanced boot time defrag capability is able to defragment files that otherwise would remain fragmented such as the Windows pagefile.sys or the file system's MFT (Master File Table) and provides the best boot time defrag operation.
Total disk defragmentation and free space consolidation
PerfectDisk offers the most comprehensive solution for defragmentation by optimizing virtually every file on the system, including the Master File Table (MFT), all NTFS metadata files, paging files, directories, and datafiles, and completely consolidating free space. And it does it all in a single pass. There's also a Selected Files Defrag option that is useful for defragmenting very large files such as video files, rather than defragmenting the entire drive.
Standard Multi-Gigabyte and Multi-Terabyte Drive Support
PerfectDisk defragments the very largest disk drives that are prevalent in today's operating environments - drives that range from several hundred gigabytes to several terabytes. Support for RAID and Volume Sets enables powerful defragmentation for the largest and most complex environments with large storage arrays and volumes. Because of this design, PerfectDisk not only defragments these large drives completely, but it does so at up to twice as fast as other defragmenters, consolidates the drives' free space, and uses 80% fewer resources - at no extra cost.
S.M.A.R.T. Monitoring
New S.M.A.R.T. monitoring capabilities monitor the status of physical drives. It generates warnings and alerts for hardware performance and reliability, helping you ensure you are aware of any potential hardware problems.
CPU and I/O - Control Resource Throttling
Perfectdisk provides resource throttling capabilities to manage resource usage as efficiently as possible. I/O throttling allows PerfectDisk to run on very busy disks without imposing additional load on the disk. CPU throttling allows you to raise or lower the CPU priority at which it runs. PerfectDisk uses very minimal CPU resources in its standard processing.
http://www.filesonic.com/file/1253167801/Perf...ginal.part1.rar
http://www.filesonic.com/file/1253167821/Perf...ginal.part2.rar
http://www.filesonic.com/file/1253167831/Perf...ginal.part3.rar
http://www.filesonic.com/file/1253167841/Perf...ginal.part4.rar
Mirror:
http://www.wupload.com/file/23230503/Perf...ginal.part1.rar
http://www.wupload.com/file/23230371/Perf...ginal.part2.rar
http://www.wupload.com/file/23230379/Perf...ginal.part3.rar
http://www.wupload.com/file/23230094/Perf...ginal.part4.rar
