PHOENIX PROGRAMMER Devresi
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 10 Kasım 2010 başlatılmıştır.
    This Phoneix programmer is based on the version previous released by Odin.
    Joos Design have added a better power supply and made some other small changes.
    We presume a Phoenix programmer will not be your first build, so a detailed instruction is not supplied.
    The PCB drawing shuld be downscaled to about 12 % of the original,
    make a test printout and verify you have the right distance for the IC legs.
    PART LIST FOR PHOENIX PROGRAMMER
    POS NO SPEC. RS PART NO.
    __________________________________________________________
    1 Main board
    2 Smart Card Connector 197-1197
    3 9 Way D connector - socket 446-585
    4 Fastening Screws
    5 DC Power Connector 486-662
    6 Heat Sink - only needed for heavily use L=19mm W=13mm
    7 5V Regulator 853-371
    8 Fastening Screw
    9 Bridge Rectifier 657-088
    10 Resistor 20K ohm 163-763
    11 Resistor 220 ohm 149-650
    12 Resistor 220 ohm 149-650
    13 Resistor 220 ohm 149-650
    14 Resistor 2K2 ohm 149-739
    15 Resistor 1M ohm 149-975
    16 Not used
    17 Crystal 3.579 MHz 226-1500
    18 Capacitor 1 uF 200-6167
    19 Capacitor 0.1 uF 115-988
    20 Capacitor 0.33 uF 116-032
    21 Capacitor 100 pF 128-168
    22 Capacitor 27 pF 128-763
    23 Capacitor 27 pF 128-763
    24 Capacitor 33 uF - only needed for heavy use 116-880
    25 LED green 590-345
    26 LED red 590-339
    27 IC 7407N 306-336
    27b IC socket 14 pin 447-314
    28 IC MAX232ECPE 225-8510
    28b IC socket 16 pin 447-320
    29 IC 74HC04N 217-5550
    29b IC socket 14 pin 447-314
    30 Secondary board, on top of smartcard connector.
    Mount everything but the secondary board, leds and ICs
    Mount top of leds into the secondary board, fasten secondary board to top of smartcard connector
    after carefully first having put the led legs through the holes in main board.
    Finally , ground yourselves to get rid of any statics and mount the ICs.
    Son düzenleme: 14 Mart 2013
Benzer Konular - PHOENIX PROGRAMMER Devresi
