Photodex ProShow Producer 4.51.3003 StylePack,Bonuses,Effects
Konusu 'Program Arsivi' forumundadır ve haingoc tarafından 19 Haziran 2011 başlatılmıştır.
  1. haingoc
    haingoc Guest
    Jun 2011 | 3.04 GB
    ProShow Producer - program for creating professional presentations from Photodex. Utility supports working with layers and provides an opportunity to use an unlimited number of layers for each slide. The program supports transparency for files PSD, PNG, TIFF and GIF, makes it possible to use a mask layer,transition effects, gradient fills or fill color. Photos that make up the presentation, you can edit, and address them with tools such as sharpen, change the contrast and color saturation. The presentation may contain signatures, including animation, background music. The finished project can be saved in one of 14 formats, including HD Video, Flash and QuickTime. This version is the most functional version of all three versions of this program, as well as fully suitable for business use.
    Some possibilities:
    "Adding an unlimited number of layers to any slide
    "Support for Drag-and-drop
    "Supports over 100 formats
    Transparency support for PSD, PNG, TIFF and GIF files
    "Adding a gradient fill, or as a separate layer to get incredible results
    "Use transition effects for individual layers
    "Built-in image correction tools (sharpen, blur, colorize, saturation, etc.)
    "Creating an enhanced framework for your photo and video
    "Cutting and turning your photos and videos with precision
    "Remove red eye using the built-in tool
    "Scaling the X and Y coordinates for each individual layer
    "Fully customizable slide preview grid allows you to accurately set the position for your photos and video
    "Controlling the fonts, sizes and colors of captions to slides
    "Animating signatures to the slides with various built-in effects
    "Using sound to your slideshow
    "Support for WAV and MP3 formats for audio
    "Preserving audio tracks directly from CD-ROM and direct dragging sounds into your slides
    And much more ...
    Additional features in this version:
    "Copy-protected CD
    "Overlay watermark on images and videos
    "Custom Templates
    "Capture frame
    "Compressing AVI output
    "Smoothing the transitions
    "The use of textures in signatures
    "The use of the gradient in signatures
    "Use of signature style
    "The use of interlinear spaces in the signatures
    "Rotate signatures
    "Set the shadow color and transparency
    "Creating vignettes
    "Support for RAW-files
    "Office Keyboard
    And much more
    New features:
    "Styles slides are preset effects that you can apply to any slide in your show
    "Adding notes to the sections, slides, or showing
    "Editing keyframes with light using the new editor of keyframes
    "The smearing of any image or video in your slide show
    "Like Adobe Photoshop, ProShow Producer 4.5 now allows you to adjust the layers to each slide
    "The new audio synchronization tool
    "Support for animated GIF images
    "Setting the strata titles
    "Rotate or flip video
    "The enhanced audio controls
    "The new settings automatically saved
    "Options menu using the right mouse button
    "Display time in seconds in the timeline
    Update Jun 2011 :
    Transitions are checked, works fine. Can be used as the wedding theme (rings, hearts, flowers), and for other themes (cloud, fog, explosions, spotlights)
    Install in the usual Producer - copy of the downloaded files folder to a shared folder C: \ Program files \ Photodex \ ProShowProducer \ transition. After that, download the Producer, click on the transition between slides, including the editor of transitions, and there you should see a new folder navigation DJ Hoaly. Going into it, will see 65 new transitions.
    The presence of the English language there is only a description of the effect in the rest of it does not interfere, since the action itself is the effect you see on the home screen editor transitions.
    Feature of the installation in portable version Producer:
    Of the included Producer to enter the menu Slide - Managing transitions - Add transitions - Add. Find the folder with the transitions, enter into it, noting any file transfer, and then press Ctrl-A (check all files of a folder) and click Download.
    Download is 2-3 minutes. Then load the next folder and so all the 4 folders transitions. In the Go menu, you will immediately see the section DJ Hoaly. Further, as usual
    http://www.filesonic.com/file/1244396171/P3003.part1.rar
    http://www.filesonic.com/file/1244402071/P3003.part2.rar
    http://www.filesonic.com/file/1244402011/P3003.part3.rar
    http://www.filesonic.com/file/1244406771/P3003.part4.rar
    http://www.filesonic.com/file/1244415781/P3003.part5.rar
    http://www.filesonic.com/file/1244416031/P3003.part6.rar
    http://www.filesonic.com/file/1244411191/P3003.part7.rar
    Mirror:
    http://www.wupload.com/file/21522023/P3003.part1.rar
    http://www.wupload.com/file/21522280/P3003.part2.rar
    http://www.wupload.com/file/21522378/P3003.part3.rar
    http://www.wupload.com/file/21522647/P3003.part4.rar
    http://www.wupload.com/file/21523053/P3003.part5.rar
    http://www.wupload.com/file/21523013/P3003.part6.rar
    http://www.wupload.com/file/21522830/P3003.part7.rar
Benzer Konular - Photodex ProShow Producer
  1. zac34
  2. efe775
