Photodex ProShow Producer & Gold v4.52.3049 ProShow StylePack (2011)
Konusu 'Program Arsivi' forumundadır ve haingoc tarafından 8 Haziran 2011 başlatılmıştır.
  1. haingoc
    haingoc Guest
    Photodex ProShow Producer & Gold v4.52.3049 ProShow StylePack (2011) | 1.77 GB
    Photodex ProShow Producer - program for creating professional presentations from Photodex. Utility supports working with layers and provides an opportunity to use an unlimited number of layers for each slide. The program supports transparency for files PSD, PNG, TIFF and GIF, makes it possible to use a mask layer, transition effects, gradient fills or fill color.
    Year: 2011
    Version: v4.52.3049
    Compatibility with Vista: complete
    Compatible with Windows 7: complete
    Language: English Russian (Russifikator)
    Medicine: Present
    System requirements:
    Windows 7, Vista, XP, 2000 (64-bit Windows 7, Vista, XP)
    1024x768 monitor
    1 GHz processor
    1 GB RAM
    Video card with 3D-accelerator (64 MB)
    DirectX 8.0 or higher
    DVD R / RW /-R / RW burner
    1,5 GB of free disk space
    Photos that make up the presentation, you can edit, and address them with tools such as sharpen, change the contrast and color saturation. The presentation may contain signatures, including animation, background music. The finished project can be saved in one of 14 formats, including HD Video, Flash and QuickTime. This version is the most functional version of all three versions of this program, as well as fully suitable for business use.
    Some possibilities:
    ? Add an unlimited number of layers to any slide;
    ? Supports Drag-and-drop;
    ? Supports over 100 formats;
    ? Transparency support for PSD, PNG, TIFF and GIF files;
    ? Adding a gradient fill, or as a separate layer to get incredible results;
    ? Use transition effects for individual layers;
    ? Built-in image correction tools (sharpen, blur, colorize, saturation, etc.);
    ? Creating an enhanced framework for your photos and video;
    ? Cutting and turning your photos and videos with precision;
    ? Remove red eye using the built-in tool;
    ? Scaling the X and Y coordinates for each individual layer;
    ? Fully customizable slide preview grid allows you to accurately set the position for your photos and video;
    ? Controlling the fonts, sizes and colors of labels to the slides;
    ? Animating signatures to the slides with various built-in effects;
    ? Using sound to your slideshow;
    ? Support for WAV and MP3 formats for audio
    ? Preservation of audio tracks directly from CD-ROM and direct dragging sounds into your slides;
    ? And much more ...
    Additional features in this version:
    ? Copy-protected CD;
    ? Overlay watermark on images and video;
    ? Custom templates;
    ? Capture frame;
    ? Compress AVI output;
    ? Smoothing the transitions;
    ? The use of textures in signatures;
    ? Use a gradient in the captions;
    ? Use of signature style;
    ? Using the interlinear spaces in the signatures;
    ? Rotate signatures;
    ? Set the shadow color and transparency;
    ? Creation of vignettes;
    ? Support for RAW-files;
    ? Keypad;
    ? And much more.
    New features:
    ? Styles slides are preset effects that you can apply to any slide in your show;
    ? Adding notes to the sections, slides, or showing;
    ? Editing key frames with light using the new editor of key personnel;
    ? Blurring of any images or video in your slide show;
    ? Like Adobe Photoshop, ProShow Producer 4.5 now allows you to adjust the layers to each slide;
    ? The new audio synchronization tool;
    ? Support for animated GIF images;
    ? Set the names to the layers;
    ? Rotate or flip video;
    ? Improved audio controls;
    ? New settings automatically saved;
    ? Options menu using the right mouse button;
    ? Displays the time in seconds in the timeline.
    Photodex ProShow Gold - The program provides professional training system settings, also supports Drag-and-drop, which speeds up work with the program. Among other features worth mentioning the possibility of adding a large number of effects and a soundtrack of your choosing. The program supports more than 40 formats for preservation, including formats such as DVD, Blu-Ray, CD, EXE, Flash, HD Video and more. The latest version adds support for Blu-ray, expanded opportunities to work with key personnel, added the possibility of ripping audio CDs and save them to MP3 for use in the slideshow.
    Unlike the version of Producer of the program, Gold-version does not have the capacity-oriented businesses, but perfectly suitable for home use.
    History:
    ProShow Producer Version 4.52
    Version 4.52.3049
    May 20, 2011
    Please Note: ProShow 4.52 provides a number of fixes and adjustments. Many of these changes may be be available to users of older versions by updating the burning support (Help> Upgrade DVD / Blu-ray / CD Support) and updating the Device support (Create> YouTube, click on the green Upgrade bar).
    Added new profiles to Device output option
    Removed direct Vimeo upload option due to change in service (now focuses on creating Vimeo-ready file and saving to disk)
    Changed label in Copy Settings dialog from Motion Style to Motion Speed
    Fixed problem with optical drive detection on some systems which could prevent DVD, CD and Blu-ray burning from working properly.
    Fixed rare installation failure affecting some systems
    Fixed rare crash caused by Internet connections on some systems
    Fixed crash affecting Presenter based output formats
    Fixed crash when opening certain existing shows
    Fixed crashes in video rendering
    Fixed problem with MPEG4 based Flash output, now supports Flash 10.x.
    Fixed problem with caption textures not being properly saved and loaded
    Fixed problem with M4A audio files
    Fixed problem where some valid audio files could fail to import
    Fixed problem where Random Transition Effects could corrupt show
    Fixed problems with program defaults after loading a project file
    Fixed problem with modifiers and red eye correction
    Fixed problem where Facebook output could fail
    Fixed problem with YouTube tags
    Fixed problems with IPTC caption macros
    Fixed missing warning message in modifier dialog
    Fixed problem with Save Window Layout dialog
    Fixed typo in modifier dialog
    Fixed typos in help documentation
    Fixed missing EULA in help documentation
    Fixed reference to Legal Notices in help documentation
    Fixed audio menu shortcut (Alt A) in help documentation
    Fixed project file extension (PPR) in help documentation
    ProShow Gold Version 4.52
    Version 4.52.3049
    May 20, 2011
    Fixed audio menu shortcut (Alt A) in help documentation.
    http://www.filesonic.com/file/1159293184/PP.v4.52.3049.STYLE.part1.rar
    http://www.filesonic.com/file/1159293244/PP.v4.52.3049.STYLE.part2.rar
    http://www.filesonic.com/file/1159293234/PP.v4.52.3049.STYLE.part3.rar
    http://www.filesonic.com/file/1159298014/PP.v4.52.3049.STYLE.part4.rar
    http://www.filesonic.com/file/1159282581/PP.v4.52.3049.STYLE.part5.rar
Benzer Konular - Photodex ProShow Producer
  1. zac34
  2. efe775
