PHP Advanced Transfer Manager Conf.php Ayarları Nasıl yapılır.
Konusu 'Görsel ve Resimli Anlatımlar' forumundadır ve guclusat tarafından 30 Eylül 2010 başlatılmıştır.
    PHP:
    <?php
     *                                 conf.php
     *   begin                : Tuesday', Aug 15', 2002
     *   copyright            : ('C) 2008-2009 phpATM Dev Team
     *   email                : flavaclown.de/contact.php
     *   $Id: conf.php, v1.31 05/07/2009 15:01 Flava Clown $
     *   This program is free software; you can redistribute it and/or modify
     *   it under the terms of the GNU General Public License as published by
     *   the Free Software Foundation; either version 2 of the License', or
     *   ('at your option) any later version.
    if ( !defined('IN_PHPATM') )
    { die(
    "Hacking attempt"); }
    // PHP scripts file extension, change it only if your server requires a
    // different name for php scripts. Rememember to rename all .php files
    // with the new extension EXCLUDING 'conf.php'
    $phpExt 'php';
    //    Don't touch this include
    include($include_location.'include/constants.'.$phpExt);
    // URL link to homepage (the link under "home" icon).
    // These value will not influence the script working
    $homeurl "http://guclusat.gu.funpic.de/";
    // The name of administrator (usually your name)
    $admin_name 'Guclusat';
    // Administrator e-mail address
    $admin_email 'guclusat@hotmail.com';
    // If your site has the mail function disabled you can use the SMTP e-mailer.
    // Just set $use_smtp to true, fill $smtp_host with your smtp server (something
    // like smtp.yourisp.net) and, if required, your username and password.
    // Note that if you use 'localhost' as host, password and username normally
    // are not required.
    $use_smtp false;
    $smtp_host ='';
    $smtp_username '';
    $smtp_password '';
    // $domain_name: the domain of your site without trailing 'http://' (eg. www.mysite.net)
    // $script_folder_path: the path where phpATM is located relative to the domain name
    $domain_name 'localhost';
    $script_folder_path 'phpATM';
    // Do NOT change this!!!
    if($script_folder_path != '')
    $installurl 'http://' $domain_name '/' $script_folder_path; }
    else
    $installurl 'http://' $domain_name; }
    // You have to change next settings if you wish use non-default folders
    // Highly recommended to change folders name to improve security
    $users_folder_name 'users';
    $userstat_folder_name 'userstat';
    $uploads_folder_name 'files';
    $languages_folder_name 'languages';
    $stats_folder_name 'stats';
    $viewers_folder_name 'viewers';
    $cfg_folder_name 'cfg';
    // Cookie settings. Normally changing these settings is not required.
    // If you want to limit the cookie validity to a particular
    // path or domain enter it in $cookiepath and $cookiedomain; set $cookiesecure
    // true only if your server is SSL Secure. The default cookie validity is set to 1 year
    // (24 * 365 = 8760 hours), you can decrease it if you want
    $cookiedomain '';
    $cookiepath '';
    $cookiesecure false;
    $cookievalidity 8760//hours
    // User type grants
    // view:     user can view the file list
    // modwon:   user can modify name and description of own files only
    //             NOTE: if modall is true, the value of modown will be ignored (assumed true)
    // delown:   user can delete own files only
    //             NOTE: if delall is true, the value of delown will be ignored (assumed true)
    // download: user can download files
    //           NOTE: if view is false then the value of download will be ignored (assumed false)
    // mail:     user can mail files to his own mail address with size limitation (see mailall)
    //           NOTE: if view is false then the value of mail will be ignored (assumed false)
    // upload:   user can upload files
    // mkdir:    user can create directories
    // modall:   user can modify name and description of all files and directories
    // delall:   user can delete any files or directories
    // mailall:  user can send files to his own mail address without size limitation
    // webcopy:  user can upload files by http address
    // validate: user can validate new uploaded file
    // Consider following lines as a table and modify true to false and viceversa paying
    // attention to not delete commas or parentesis nor other special chars.
    // Please don't change uppercase values!!
    //  STATUS    => array(view,    modown,  delown,  download, mail,    upload,  mkdir,   modall,  delall,  mailall,  webcopy,  validate)
    //                       V        V        V        V         V        V        V        V        V        V         V         V
    $grants = array(
    ANONYMOUS => array(true,    FALSE,   FALSE,   true,     FALSE,   false,   false,   FALSE,   FALSE,   FALSE,    false,    false),
    UPLOADER  => array(true,    false,   false,   false,    false,   true,    false,   false,   false,   false,    true,     false),
    VIEWER    => array(true,    false,   false,   false,    false,   false,   false,   false,   false,   false,    false,    false),
    NORMAL    => array(true,    true,    true,    true,     true,    true,    true,    false,   false,   false,    false,    false),
    POWER     => array(true,    true,    true,    true,     true,    true,    true,    false,   false,   true,     true,     true ),
    ADMIN     => array(TRUE,    TRUE,    TRUE,    TRUE,     TRUE,    TRUE,    TRUE,    TRUE,    TRUE ,   TRUE,     TRUE,     TRUE )
    // The default status of new registered user
    // ADMIN - Administrator, POWER - Power User, NORMAL - Normal User,
    // VIEWER - Viewer (view only), UPLOADER - Uploader (upload only)
    $default_user_status UPLOADER;
    // The text displayed in the browser titlebar
    $page_title 'Uydudoktoru Yazılım Depo Test';
    // The default status of a new uploaded file:
    // 0 - new files do not require admin approval to be listed
    // 1 - admin approval is required before a new file can be listed
    $validation_enabled 0;
    // You can encrypt files content to increase security and avoid direct linking to files.
    // Remember that viewers will be disabled with encryption on. Change this setting only
    // if your file directory is empty, because with this setting off, already encrypted files
    // will be unreadable and viceversa. Permitted values are 'true' and 'false'.
    // NOTE: if you are planning to enable this setting please first change the encryption key
    // with a password of your choice.
    $encrypt_filecontent false;
    $encryption_key 'password';
    // Server timezone offset, relative to GMT (Greenwich Mean Time), in hours
    // Change this setting only if time works incorrect
    $GMToffset date('Z')/3600;
    // The time when script have to do maintenance functions
    // (delete unauhtorized users, send digest, etc.). For instance, if you want
    // to do maintenance functions after 03:00, set the value to 3.
    $maintenance_time 2;
    // Enable or disable mail functions. If disabled, the digest,
    // mail confirmation & file mailing function is off
    $mail_functions_enabled true;
    // The maximum size of file, which normal users can send to their mail (in kilobytes)
    // To disable this function (for normal users only), set size below zero
    $max_filesize_to_mail 500;
    // Enable or disable account activation via e-mail.
    // These feature helps you check the e-mail address of registered user
    $require_email_confirmation false;
    // Enable or disable language switching ability
    // Disable it if you have only one language installed.
    $allow_choose_language true;
    // The default sort order for files/folder listed in the index.php
    // possible options:
    // "nom" will sort files by name (default)
    // "mod" will sort files by their (last modified) date
    // "rating" will sort files by 'how many times they are downloaded'
    // "taille" will sort files by their filesize
    $dft_sort_order "nom";
    // The default sort direction for files/folder listed in the index.php
    // possible options: are "0" and "1", the sort direction is also affected by the sort order
    // for the newest files on top set it to 1 and $dft_sort_order to "mod"
    $dft_sort_direction "0";
    // Max number of files listed in 'last uploads' section
    // Don't exceed, since the page load can be very slow
    $max_last_files 10;
    // Max number of files listed in 'top downloads' section
    $max_topdownloaded_files 10;
    // The mail header for digest (html code allowed)
    // You can configure it in the 'settings panel' (only administrator)
    $mailinfopage='mailinfo.htm';
    // Default language, the language code of one element stored in 'languages' dir
    // Anonymous cant't configure this, so will ever use this language
    $dft_language 'tr';
    // Maximum allowed filesize to upload (Kilobytes)
    // Note: php.ini and server also have an upload size limit
    $max_allowed_filesize 24096;
    // Maximum daily allowed Mb upload - set to number of Mb allowed daily.
    // Set to -1 if you wish not to have this forced.
    $max_daily_mb = -1;
    // Maximum monthly allowed Mb upload - set to number of Mb allowed monthly
    $max_monthly_mb = -1;
    // Maximum daily download
    // Set to -1 if you wish not to have this enforced.
    $max_daily_download_mb = -1;
    // Maximum monthly download
    $max_monthly_download_mb = -1;
    // Format of date & time (in PHP time format, see php.net)
    $datetimeformat 'd.m.Y H:i';
    // Max number chars for file and directory names
    $file_name_max_caracters 150;
    // Max number chars for filename in tables
    $file_out_max_caracters 40;
    // Max number chars for file comment (description)
    $comment_max_caracters 300;
    // Reserved filename
    $reserved_files "index\.html|^\.|\.desc$|\.dlcnt$";
    // Regular expression defines which files can't be uploaded
    // If you don't know what are regular expressions, don't touch this.
    // NOTE: due to a bug of Apache/PHP, php file with any extra double chars extension
    // are executed like normal php file. I.e. test.php.xx is executed as test.php
    // This is a big security hole, fixed by the following regular expression
    // If you add any extension please consider this bug and add the control to multiextension too
    $rejectedfiles "^index\.|\.desc$|\.fdesc$|\.dlcnt$|\.vcnt$|\.php$|\.php\..*|\.php3$|\.php3\..*|\.cgi\..*|\.cgi$|\.pl$\.pl\..*|\.php4$|\.ns|\.inc$|\.php5";
    // Show hidden files (like .htaccess, etc) and directories (see $hidden_dirs)
    $showhidden false;
    // Hidden directories (regular expression) that won't be shown nor won't be
    // analized for digest, last uploads and top donwloads. Note that users can't
    // create dirs with an hidden name. Default value hides Fr*ntP*ge directories.
    $hidden_dirs "^_vti_";
    // Header & Background colors of table, Font colors
    // Only the first skin in the array currently works!
    $skins = array(
      array(
    'bordercolor' => '#E5E5E5',    // The table border color
    'headercolor' => '#F1F1F1',    // The table header color
    'tablecolor' => '#FFFFFF',     // The table background color
    'lightcolor' => '#FFFFFF',     // Table date field color
    'headerfontcolor' => '#000000',
    'normalfontcolor' => '#000000',
    'selectedfontcolor' => '#4682B4',
    'bodytag' => "bgcolor=\"#E5E5E5\" text=\"#000000\" link=\"#000000\" vlink=\"#333333\" alink=\"#000000\""
    // Text font used in every page
    $font 'Verdana';
    // Mimetypes, feel free to change the list but don't remove 'directory' and 'default'.
    // Make sure that the specified image exists in 'images' folder and follow
    // the existing structure
    $mimetypes = array (
    '.txt'  => array('img' => 'txt.gif',    'mime' => 'text/plain'),
    '.html' => array('img' => 'html.gif',   'mime' => 'text/html'),
    '.htm'  => array('img' => 'html.gif',   'mime' => 'text/html'),
    '.doc'  => array('img' => 'doc.gif',    'mime' => 'application/msword'),
    '.pdf'  => array('img' => 'pdf.gif',    'mime' => 'application/pdf'),
    '.xls'  => array('img' => 'xls.gif',    'mime' => 'application/msexcel'),
    '.gif'  => array('img' => 'gif.gif',    'mime' => 'image/gif'),
    '.jpg'  => array('img' => 'jpg.gif',    'mime' => 'image/jpeg'),
    '.jpeg' => array('img' => 'jpg.gif',    'mime' => 'image/jpeg'),
    '.bmp'  => array('img' => 'bmp.gif',    'mime' => 'image/bmp'),
    '.png'  => array('img' => 'gif.gif',    'mime' => 'image/png'),
    '.zip'  => array('img' => 'zip.gif',    'mime' => 'application/zip'),
    '.rar'  => array('img' => 'rar.gif',    'mime' => 'application/x-rar-compressed'),
    '.gz'   => array('img' => 'zip.gif',    'mime' => 'application/x-compressed'),
    '.tgz'  => array('img' => 'zip.gif',    'mime' => 'application/x-compressed'),
    '.z'    => array('img' => 'zip.gif',    'mime' => 'application/x-compress'),
    '.exe'  => array('img' => 'exe.gif',    'mime' => 'application/x-msdownload'),
    '.mid'  => array('img' => 'mid.gif',    'mime' => 'audio/mid'),
    '.midi' => array('img' => 'mid.gif',    'mime' => 'audio/mid'),
    '.wav'  => array('img' => 'wav.gif',    'mime' => 'audio/x-wav'),
    '.mp3'  => array('img' => 'mp3.gif',    'mime' => 'audio/x-mpeg'),
    '.avi'  => array('img' => 'avi.gif',    'mime' => 'video/x-msvideo'),
    '.wmv'  => array('img' => 'avi.gif',    'mime' => 'video/x-ms-wmv'),
    '.mpg'  => array('img' => 'mpg.gif',    'mime' => 'video/mpeg'),
    '.mpeg' => array('img' => 'mpg.gif',    'mime' => 'video/mpeg'),
    '.mov'  => array('img' => 'avi.gif',    'mime' => 'video/quicktime'),
    '.swf'  => array('img' => 'flash.gif',  'mime' => 'application/x-shockwave-flash'),
    '.gtar' => array('img' => 'rar.gif',    'mime' => 'application/x-gtar'),
    '.tar'  => array('img' => 'rar.gif',    'mime' => 'application/x-tar'),
    '.tiff' => array('img' => 'defaut.gif''mime' => 'image/tiff'),
    '.tif'  => array('img' => 'defaut.gif''mime' => 'image/tiff'),
    '.rtf'  => array('img' => 'doc.gif',    'mime' => 'application/rtf'),
    '.eps'  => array('img' => 'defaut.gif''mime' => 'application/postscript'),
    '.ps'   => array('img' => 'defaut.gif''mime' => 'application/postscript'),
    '.qt'   => array('img' => 'avi.gif'  ,  'mime' => 'video/quicktime'),
    'directory' => array('img' => 'dossier.gif''mime' => ''),
    'default' =>   array('img' => 'defaut.gif',  'mime' => 'application/octet-stream')
    // Chars removed from filename and directory name for safety purposes
    // Avoid to modify it unless you are sure about what are you doing.
    $invalidchars = array (
    // Insert here IP addresses that are not allowed to access your site
    // Default values should not exist, but are present to show you how
    // insert them. If you want you can delete them.
    // Warning IP address in this list must be numerical!
    $ip_black_list = array (
    '127.0.0.2',
    '127.0.0.3'
    // config part for the register.php
    // here you can allow some extra characters for usernames such as é è ç à @
    // but keep in mind that usernames are also filenames! not every character can be used!
    // e.g. $extra_character = 'éèçà@';
    $extra_character "àá";
    // here you can set the lenght for usernames (default 12)
    $username_lenght "22";
    // The optional register info file
    $register_infopage "register_info.htm";
    // config part for the login.php
    // allows you to enable (true) or disable (false)
    // the "Still not registered? - Register here!" table
    $registertable_enabled true;
    // the "Forget your password?" table
    $password_reminder_table_enabled true;
    Düzenleme yaptığım dosya yıkardadır elinizdeki ile kontrol ederek değişiklikleri görebilirsiniz
