Power LED Strobe
Konusu 'Güç Kaynakları - Besleme Devreleri' forumundadır ve uydudoktoru tarafından 23 Şubat 2015 başlatılmıştır.
    Description
    This project functions as a simple strobe for driving a high power type LED. The output driver provides current limiting suitable for use with either 350mA / 1 Watt LEDs or 700mA / 3 Watt LEDs.
    Output from these LEDs is extremely bright and visible from a considerable distance, even in daylight.
    Four jumpers provide options for changing the pulse width, strobe repeat interval and single or double strobe flash. There is also a Strobe Inhibit input that can be used to stop the strobe pulse using a switch. The programmer ready code has default timings which are easily customised by editing values in the PIC's EEPROM at programming time.
    [​IMG] Warning. The light output from Power LEDs is very intense. Avoid looking directly at the LED when operating.
    Schematic
    [​IMG][​IMG][​IMG]
  2. uydudoktoru
