Precison Power Supply, 0-40V/2A
Konusu 'Elektronik Devreler' forumundadır ve uydudoktoru tarafından 15 Temmuz 2011 başlatılmıştır.
    Parts List:
    Resistors:
    All resistors are 1/4W unless otherwise indicated
    R1 = 1K2 RV1,RV2 = 5K R
    2 = 7K5 RV3 = 500 ohm
    R3 = 15K RV4 = 100K
    R4 = 160 Ohm
    P1 = 50K, Bourns, 10-turn potentiometer
    R5,R6 = 0.22 ohm, 5W
    P2 = 500 ohm potentiometer
    R7 = 10K, 1W R
    8 = 180K R
    9 = 330K, 1WN
    ote: R5 and R6 are "wire-wound" types
    Capacitors:
    C1,C2 = 2200uF, 100V, electrolytic
    C3 = 1500uF, 50V, electrolytic
    C4,C7 = 0.1uF, 25V, ceramic
    C5 = 10pF, 25V, ceramic C
    6 = 240pF, 25V, ceramic
    C8 = 100uF, 100V, electrolytic
    C9 = 22nF (0.022uF), 100V, polyester or similar
    Semiconductors:
    D1-D8 = 1N4007 Br1 = 6A, 200V
    Bridge Rectifier, KBPC102 or similar
    Br2 = 1A, 50V Bridge Rectifier, MDA100A or similar
    1 = TIP31C, NPN power transistor
    TO-220 (NTE184)
    Q2 = 2N6385, NPN power transistor, T
    O-3 (NTE245) IC1 = MC1466L, p
    recision regulator IC, 14-pin DIL (no known substitute) L
    ed1 = LED, your choice on/off indicator
    Miscellaneous:
    T1/T2 = Transformer with two windings; 17VAC/300mA, and 36VAC/3A (JS-92-096) (or two separate transformers, but will take more space) S1 = SPDT, Power on-off switch (the Led1 for on/off can be part of S1)J1,J2,J3 = Binding posts, one Red (+), one Black (-), one green (Gnd.) Knobs = 2 knobs for voltage and current potentiometersOther:Heatsink for transistors Q1 and Q22 meters 250uA (microAmp) eachCabinet or enclosure Hammond 1458 series. ps4002b.JPG
Benzer Konular - Precison Power Supply
