Rangkaian Boster Radio Penerima FM
Konusu 'Fm Verici Devreleri' forumundadır ve guclusat tarafından 16 Mart 2013 başlatılmıştır.
    2SC2570. (Only C2570 is annotated on the transistor body.) Assemble the circuit on a good-quality PCB (preferably, glass-epoxy). Adjust input/ output trimmers (VC1/VC2) for maximum gain.
    All capacitors are ceramic and 50V is the standard but the 25V types work fine too. Trimmer capacitors Tr1 and Tr2 (22pF) are adjusted for maximum gain. Input coil L1 consists of 4 turns of 20SWG enamelled copper wire over a 5mm diameter former. It is tapped at the first turn from the ground lead side. Coil L2 is similar to L1, but has only three turns. Pin configuration is shown in the diagram.
    Component List:
    R1 = 27K
    R2 = 270 ohm
    R3 = 1K
    Tr1,Tr2 = 22pF, trimmer cap (15-40pF)
    C1,C2 = 5.6pF
    C3 = 0.001uF (1nF), ceramic
    C4,C5 = 10pF, ceramic
    C6 = 0.1uF (100nF), ceramic
    Q1 = 2SC2498, 2SC2570, 2N5179, SK9139, or NTE10. NPN VHF/UHF transistor
    L1 = 4 turns of 20SWG magnet wire, 5mm diameter. (so-called 3T+1)
    L2 = 3 turns of 20SWG magnet wire, 5mm diameter.
Benzer Konular - Rangkaian Boster Radio
