Room Noise Detector (Oda Gürültü Dedektörü )
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 9 Kasım 2011 başlatılmıştır.
    Online
    One LED monitors three levels: 50, 70 & 85 dB, Useful to detect too noisy environments
    This circuit is intended to signal, through a flashing LED, the exceeding of a fixed threshold in room noise, chosen from three fixed levels, namely 50, 70 & 85 dB. Two Op-amps provide the necessary circuit gain for sounds picked-up by a miniature electret microphone to drive a LED. With SW1 in the first position the circuit is off. Second, third and fourth positions power the circuit and set the input sensitivity threshold to 85, 70 & 50 dB respectively. Current drawing is 1mA with LED off and 12-15mA when the LED is steady on.
    Circuit diagram:
    Parts:
    R1 = 10K
    R2 = 22K
    R3 = 22K
    R4 = 100K
    R5 = 56K
    R6 = 5.6K
    R7 = 560R
    R8 = 2.2K
    R9 = 56K
    R10 = 56K
    R11 = 1K
    R12 = 33K
    R13 = 330R
    C1 = 100nF-63V
    C2 = 10µF-25V
    C3 = 470µF-25V
    C4 = 47µF-25V
    D1 = 5mm. Red LED
    Q1 = BC327
    B1 = 9V PP3 Battery
    SW1 = 2 poles 4 ways rotary switch
    IC1 = LM358 Low Power Dual Op-amp
    MIC1 = Miniature electret microphone
    Use:
    • Place the small box containing the circuit in the room where you intend to measure ambient noise.
    • The 50 dB setting is provided to monitor the noise in the bedroom at night. If the LED is steady on, or flashes bright often, then your bedroom is inadequate and too noisy for sleep.
    • The 70 dB setting is for living-rooms. If this level is often exceeded during the day, your apartment is rather uncomfortable.
    • If noise level is constantly over 85 dB, 8 hours a day, then you are living in a dangerous environment.
    Son düzenleyen: Moderatör: 9 Kasım 2015
Benzer Konular - Room Noise Detector
