Simple negative power supply (-5V / -12V / -15V)
Konusu 'Smps Devreleri Ve Uygulamaları' forumundadır ve guclusat tarafından 18 Mayıs 2010 başlatılmıştır.
    Sometimes you need a simple negative power supply. The best example is the contrast PSU for common small LCD device. Building -5V from a battery or a wallmart supply isn’t really easy. I decided to build a small device that is able to provide -5V, -12V, -15V. I used the MAX 764/765/766 serie. Simply change the chip to provide the good output.
    Here the little schematic:
    And here a pic, of the result:
    As you can see, this stuff is damm small, use some common parts and can be reuse across different needs. Thanks Maxim for the sample :)
    I used a 220uF instead of the 120uF one, and a small inductor but you can use a bigger one, if you need greater current.
