Simple Solar Tracker
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 28 Mayıs 2014 başlatılmıştır.
    Bill of Materials
    Component........Jaycar..Qty Names
    7812...Pos Reg...ZV-1512...1..U3
    LM317T.Pos Reg...ZV-1615...1..U4
    BC548..NPN.......ZT-2154...1..Q1 or BC549
    CAP....0.1uF.....RC-5490...8..C5 C6 C2 C7 C8 C9 C10 C11
    CAP....47uF......RL-6434...1..C1
    CAP....1uF.......RL-6414...1..C3
    4 pin Header.....HM-3114...1..SK2
    8 pin Header.....HM-3118...1..SK1
    4 pin Plug.......HM-3124...1..SK2
    8 pin Plug.......HM-3128...1..SK1
    1N914..Sig Diode.ZR-1100...5..D4 D1 D2 D3 D10
    1N4004..Diode....ZR-1004...2..D11 D12 or 1N4001
    1N5404..Diode....ZR-1015...1..D5
    1N5822..Diode....ZR-1023...4..D6 D7 D8 D9
    LM324.. op amp...ZL-3324...1..U1
    14 pin DIL Skt...PI-6454...1..U1
    NE555P….Timer....ZL-3555...1..U2
    8 pin DIL Skt....PI-6452...1..U2
    4n33 Opto cplr...xx-xxxx...2..IC1 IC6
    I used the above or use
    4n28 Opto cplr...ZD-1628...2..IC1 IC6
    6 pin DIL skt....PI-6450...2..IC1 IC6
    ORP12...LDR......RD-3480...3..LDR3 LDR1 LDR2
    LED Red..........ZD-0150...1..
    LED orange.......ZD-0169...1..
    LED Green........ZD-0170...1..
    LED Yellow.......ZD-0160...1..
    Res-¼w..82R......RR-0546...1..R29
    Res-¼w..560R.....RR-0566...2..R12 R11
    Res-¼w..1k.......RR-0572...7..R4 R3 R22 R23 R26 R27 R28
    Res-¼w..1k2......RR-0574...4..R13 R16 R20 R21
    Res-¼w..2K2......RR-0580...2..R17 R18
    Res-¼w..4K7......RR-0588...2..R14 R15
    Res-¼w..10k......RR-0596...5..R1 R2 R19 R24 R25
    Res-¼w..18k......RR-0602...1..R8
    Res-¼w..22k......RR-0604...1..R7
    Res-¼w..100k.....RR-0620...3..R9 R5 R6
    Res-¼w..1M.......RR-0644...1..R10
    Trip Pot…1k......RT-4354...1..VR3
    Trip Pot…10k.....RT-4360...1..VR2
    Trip Pot…20k.....RT-4362...1..VR1
    STP16NE06.P FET..ZT-2277...2..IC5 IC4
    IRF9540.N Ch FET.ZT-2467...2..IC2 IC3
    or TIP32 & TIP33 for 3A
    switching.. bit cheaper
    TO220 insulators HP-1155...1..
    M3x12mm Bolts....HP-0140...1..
    M3 Nuts .........HP-0146...1..
    M3 Washers.......HP-0148...1..
    SPDT CO .........ST-0554...1..
    DPDT CO .........ST-0555...1..
    IP65 Alum Box....HB-5042...1..
    Cable Glands.....HP-0732...1..
    Son düzenleyen: Moderatör: 9 Temmuz 2015
