Here you can download the SMD code book that shows SMD marking codes for almost every surface-mount device available on the market. To identify a particular device, first identify the package style and note the ID code printed on the device.
Next look up the code in the alphanumeric listing which forms the main part of the pdf book by looking for the first character in the left column. You can use the CTRL + F shortcut to search for a certain SMD code because it will be hard to look through 3400 codes, with type numbers, characteristics or equivalents and pinout information.
