SMD ile ilgili Kısaltmalar
Konusu 'Genel Elektronik' forumundadır ve guclusat tarafından 1 Mart 2013 başlatılmıştır.
    Kısaltmalar
    [TABLE="width: 708"]
    [TR]
    [TD="width: 241"]Eleman Kısaltmaları[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]amp..................................................[/TD]
    [TD="width: 459"]amplifikatör[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]atten ...............................................[/TD]
    [TD="width: 459"]attenuatör[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]a .....................................................[/TD]
    [TD="width: 459"]anot[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]b .....................................................[/TD]
    [TD="width: 459"]beys (base)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]c .....................................................[/TD]
    [TD="width: 459"]katot (cathode)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]ca ...................................................[/TD]
    [TD="width: 459"]ortak anot (common anode)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]cc ...................................................[/TD]
    [TD="width: 459"]ortak katot (common cathode)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]comp.............................................[/TD]
    [TD="width: 459"]tamalayıcı (complement)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]d ....................................................[/TD]
    [TD="width: 459"]drain[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]dg ..................................................[/TD]
    [TD="width: 459"]çift kapılı (dual gate)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]dtr ...................................................[/TD]
    [TD="width: 459"]dijital transistör (Kodrehberi açıklamalar kısmına bakınız.)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]enh..................................................[/TD]
    [TD="width: 459"]enhancement (mode - FETs)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]fet ...................................................[/TD]
    [TD="width: 459"]alan etkili transistör (field effect transistor)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]fT ....................................................[/TD]
    [TD="width: 459"]kesim frekansı (transition frequency)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]GaAsfet .......................................[/TD]
    [TD="width: 459"]Galyum Arsenid alan etkili transistör[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]g ...................................................[/TD]
    [TD="width: 459"] geçit (gate)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]gnd ................................................[/TD]
    [TD="width: 459"]toprak, şasi (ground) [/TD]
    [/TR]
    [TR]
    [TD="width: 241"]gp ..................................................[/TD]
    [TD="width: 459"]genel amaçlı (general purpose)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]hfe ..................................................[/TD]
    [TD="width: 459"]küçük sinyal akım kazancı (small signal current gain)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]i/p ...................................................[/TD]
    [TD="width: 459"]giriş (input)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Id ....................................................[/TD]
    [TD="width: 459"]drain current[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Ig ....................................................[/TD]
    [TD="width: 459"]kapı akımı (gate current)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Ir ....................................................[/TD]
    [TD="width: 459"]reverse leakage current (diodes)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]jfet ..................................................[/TD]
    [TD="width: 459"]junction field effect transistor[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]MAG ...............................................[/TD]
    [TD="width: 459"]Enyüksek eldeedilebilen kazanç (maximum available gain)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]max ................................................[/TD]
    [TD="width: 459"]ençok, maksimum[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]min .................................................[/TD]
    [TD="width: 459"]enaz, minimum[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]mmic .............................................[/TD]
    [TD="width: 459"]Mikro dalga minyatür entegre devre (microwave minature integrated circuit)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]modamp .......................................[/TD]
    [TD="width: 459"]modular amplifier - an mmic amplifier[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]mosfet ..........................................[/TD]
    [TD="width: 459"]Metal oksit yalıtım kapılı FET (alan etkili transistör) (metal oxide insulated gate fet)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]n-ch ..............................................[/TD]
    [TD="width: 459"]n- kanal FET ( n-channel fet) (any type)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]npn ...............................................[/TD]
    [TD="width: 459"]npn bipolar transistor[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]o/p .................................................[/TD]
    [TD="width: 459"]çıkış (output)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]p-ch ..............................................[/TD]
    [TD="width: 459"]p-kanal FET (p-channel fet) (any type)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]pin .................................................[/TD]
    [TD="width: 459"]pin diyodu[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]pkg ................................................[/TD]
    [TD="width: 459"]paket, kılıf (package)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]pnp ................................................[/TD]
    [TD="width: 459"]pnp bipolar transistor[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]prot ................................................[/TD]
    [TD="width: 459"]korumalı (protection, protected) (as in mosfet gate)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]res ...................................................[/TD]
    [TD="width: 459"]direnç (resistor)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]s .....................................................[/TD]
    [TD="width: 459"]source[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]ser ...................................................[/TD]
    [TD="width: 459"]seri (series)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Si ...................................................[/TD]
    [TD="width: 459"]silisyum (silicon)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]substr .............................................[/TD]
    [TD="width: 459"]substrate[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]sw ...................................................[/TD]
    [TD="width: 459"]anahtar veya anahtarlamalı (switch or switching)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Vce .................................................[/TD]
    [TD="width: 459"]en yüksek kollektör-emetör voltajı (collector - emitter voltage)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Vcc .................................................[/TD]
    [TD="width: 459"]kollektör kaynak voltajı (collector supply voltage)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"][/TD]
    [TD="width: 459"][/TD]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD="width: 241"]Üretici kısaltmaları[/TD]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD="width: 241"]
    Agi ....................................................
    [/TD]
    [TD="width: 459"]
    Agilent (eskiden HP)
    [/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Dio ...................................................[/TD]
    [TD="width: 459"]Diodes Inc[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Fch ...................................................[/TD]
    [TD="width: 459"]Fairchild[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]HP ....................................................[/TD]
    [TD="width: 459"]Hewlett-Packard (Now Agilent)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Inf ....................................................[/TD]
    [TD="width: 459"]Infineon (eskiden Siemens)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]ITT ...................................................[/TD]
    [TD="width: 459"]ITT Semiconductors[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]MC ....................................................[/TD]
    [TD="width: 459"]Mini-Circuits[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Mot ...................................................[/TD]
    [TD="width: 459"]Motorola (şimdi ON Semiconductors)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Nat ...................................................[/TD]
    [TD="width: 459"]National Semiconductor[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Nec ...................................................[/TD]
    [TD="width: 459"]NEC[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]NJRC ..............................................[/TD]
    [TD="width: 459"]New Japan Radio Co[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]ON ...................................................[/TD]
    [TD="width: 459"]ON Semiconductors (eskiden Motorola)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Phi ...................................................[/TD]
    [TD="width: 459"]Philips[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Roh ..................................................[/TD]
    [TD="width: 459"]Rohm[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]SGS .................................................[/TD]
    [TD="width: 459"]SGS-Thompson[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Sie ...................................................[/TD]
    [TD="width: 459"]Siemens (şimdi Infineon)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Sil ...................................................[/TD]
    [TD="width: 459"]Siliconix (Vishay-Silliconix)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Tem .................................................[/TD]
    [TD="width: 459"]Temic Semiconductors[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Tfk ...................................................[/TD]
    [TD="width: 459"]Telefunken (Vishay-Telefunken)[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Tok ..................................................[/TD]
    [TD="width: 459"]Toko Inc.[/TD]
    [/TR]
    [TR]
    [TD="width: 241"]Zet ...................................................[/TD]
    [TD="width: 459"]Zetex[/TD]
    [/TR]
    [/TABLE]
