Solar Charger Circuit Diagram
Konusu 'Elektronik Devreler' forumundadır ve guclusat tarafından 13 Ekim 2010 başlatılmıştır.
    Online
    Here is a solar charger circuit to charge Lead Acid or Ni-Cd batteries using solar energy. The circuit harvests solar energy to charge a 6 volt 4.5 Ah rechargeable battery for various applications. The charger has Voltage and Current regulation and Over voltage cut off facilities.
    The circuit uses a 12 volt solar panel and a variable voltage regulator IC LM 317. The solar panel consists of solar cells each rated at 1.2 volts. 12 volt DC is available from the panel to charge the battery. Charging current passes through D1 to the voltage regulator IC LM 317. By adjusting its Adjust pin, output voltage and current can be regulated. VR is placed between the adjust pin and ground to provide an output voltage of 9 volts to the battery. Resistor R3 Restrict the charging current and diode D2 prevents discharge of current from the battery. Transistor T1 and Zener diode ZD act as a cut off switch when the battery is full. Normally T1 is off and battery gets charging current. When the terminal voltage of the battery rises above 6.8 volts, Zener conducts and provides base current to T1. It then turns on grounding the output of LM 317 to stop charging.
    Son düzenleme: 13 Temmuz 2011
Benzer Konular - Solar Charger Circuit
  4. uydudoktoru
