Stabilised Power Supply with Short-Circuit Indication
Konusu 'Güç Kaynakları - Besleme Devreleri' forumundadır ve guclusat tarafından 6 Aralık 2010 başlatılmıştır.
    Here is an efficient 4-stage stabilised
    power supply unit for testing electronic
    circuits. It provides well
    regulated and stabilised output, which is
    essential for most electronic circuits to give
    proper results. The circuit provides an audio-
    visual indication if there is a short circuit
    in the PCB under test, so the power
    supply to the circuit ‘under test’ can be
    cut-off immediately to save the valuable
    components from damage.
    The circuit provides four different regulated
    outputs (12V, 9V, 6V and 5V) and
    an unregulated 18V output, which are selectable
    through rotary switch S2.
    Read more original source:
    Circuit lab, diagrams,Free circuits, Electronics periodical, e-mags: India
